Question about Refrigerators
My refrigerator is leaking water from the freezer to the inside top shelf and bottom of the refrigerator but inside I`v been putting towels in to soak it up.What can be done?
  • Refrigerators Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezermy refrigerator is leaking water from the freezer - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 30, 2010
My fridge is leaking water from the top shelf down to the bottom and onto the floor
You most likely have a clogged defrost drain tube in the freezer, this diverts water through the damper into the fridge section in units with the freezer on top... Remove the back wall of the freezer and look beneath the tubing and you will see an ice pad... Use a turkey baster and warm water to reveal the drain hole, then force warm water down it until it is clear... Have some towels handy. Whirlpool Refrigerator Drain Strap 819043
Nov 09, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
My fridge has water leaking from the freezer. It
Unplug the power to the Fridge, take the items out of the freezer. There is a bottom tray that's inside the freezer that has 2 or 4 screws, remove the screws that holds the floor to the freezer and lift it out. You will probably see a sheet of ice on the bottom of the freezer. You may have to take off the back cover which is inside the freezer, it covers the evaporator. Then you will want to defrost the ice, do not use a heat gun it will melt the inside of the freezer. Best way to thaw it is leave the power off and melt it with hot water (not boiling). Either wet vac out the water as it melts or use a hand towel to mop it up. Sometimes a turkey baster will work to squeegee it out. There is a drain hole in the back that you will see as the ice begins to melt. That needs to be clear and the only way to clear it is to cover it with hot water. You will know that it clears and working when you see the water drain out thru the drain hole in the back of the inside of the freezer. By the way the drain drains thru a pipe thru a tray that's on top of your compressor. That's what heats it and makes it evaporate. Be advised that as you see that it is clearing, you can stop dumping water down there as some may get on the floor as the pan may overflow and dump water on the floor. If that happens, just mop up the water from the floor. Now put it back together again and plug it back in and you should have no further problems.
Aug 31, 2009 | Frigidaire FRT17G4B Top Freezer...
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Jun 09, 2009 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
