Question about Sharp AQUOS Blu-ray Disc Player
I have a sharp aquos bd-16u blue ray player, I get the audio signals but I'm not getting any video signal with the component output. My tv does not have hdmi inputs but it does have component inputs. What could be the problem?
  • Sharp Master
  • 3,866 Answers
1. could be the cable you using.
2. Could be you in the wroung input
3. RaRE but it could be the Blue ray itself
You might want to try new cables the R,G,B ones..
Yiou can try it on another tv to see if that works.
in rare instances you could have a dead on arrival there,
Thanks I hope this helps please do be considerate and leave postive feedback and ratings.
Posted on May 30, 2010
Sharp TV problem LC-40E77UN Sharp Blu Ray
PLEASE place your question in the appropriate forum/section under TELEVISIONS, because this is the VACUUM section. That way, someone knowledgeable about your problem can help you.
Oct 19, 2013 | Televison & Video
Can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Jun 29, 2012 | Panasonic DMP-BD77 Blu-ray Disc Player -...
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
I'v got a sharp aquos and the blu-ray dont work on it the dvd's work? and dont no where to get it fixed can you help please?
The Sharp is not getting the go codes from the blue ray, or the blue ray is not sending them. Sony has a cool comcept to force you into buying Sony stuff. HDMI sends information down the cable that is caring the audio and video that tells the Sharp that its OK to allow the signal in. Some receivers, and or DAs do not pass this data, so the TV will not display the video and audio. Connect the blue ray player directly to the TV, and loop audio out to the receiver for the auio, and see whay happens.
Aug 30, 2010 | Audio Players & Recorders
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
Sharp Aquos 40lcd will not play bluray
You need to change the resolution on the Blu-ray to 720P to match the Tv native resolution.
Jun 26, 2009 | Televison & Video
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Apr 19, 2009 | Pioneer VSX-D514 Receiver
DMR-E80H Component output
Are you selecting the right video source on your Tvs? please ket me know or you can call.
Feb 10, 2008 | Panasonic DMR-E80H DVD Recorder
Sharp AQUOS Blu-ray Disc Player Logo
170 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
