SOLUTION: After a year and half of keeping this broken dock around and researching online to no avail, I have finally "fixed" my Memorex iListen iPod dock.
*Quick answer is that I used an old ac adaptor from a modem I no longer used but for more details, read below.
The first issue was figuring out what to search for. My iListen doesn't clearly note it's name on the unit. All I could find on it was "Memorex" so for the purpose of those Googling for a solution, I used generic search terms like "Memorex white ipod dock" plus "won't power on," "fix," "repair," and "broken." I hope including those keywords in this solution's text helps people arrive at this page as a result.
To clarify the symptoms my unit presented:
1) The power supply's green light was lit but did appear to blink, or rather it was constantly lit but would fade slightly from bright to medium before repeating in approximately two second intervals.
2) The unit would not seem to turn on; however, pressing the power button with an ipod plugged in would result in the unit momentarily turning on. It varied in length but usually only "flashed" on.
Given these circumstances, my guess was that a "blown fuse" was the cause. Since I saw no way to open up the power block or the main dock unit (not quite sure what I was gonna do once in there except look for a fuse), I decided to rummage thru some old power adapters I had lying around in an old shoe box. I found one from an old modem that matched the symbols on the original "broken" adapter. (as i found later, the symbol represents a positive polarity, more info here:
http://commons.wikimedia.org/wiki/File:AC_adaptor_polarity.png)
Once I plugged in the modem adaptor to the dock, it powered right up.
I know this was a long, LONG way around sharing a singular solution, but seeing how long it took to finally discover it (albeit an incredibly simple one), I wanted to make sure others found it and knew what circumstances specifically applied to my case.
Logik MI1006 DOES NOT PLAY my ipod
My Logik MI1006 doesnt play my ipod or the radio altogether. Only had it a year and hardly used it. The display just flashes :(
i can only play radio on mine cant get the mode to change to ipod
Same exact problem. Imation will fix it for 19.99.
