Question about Canon ES900 Camcorder
When I place the tape in the camera, it won"t stay town. I have tried several tapes with no results. Help! I need the very soon.
  • Canon Master
  • 3,866 Answers
Something is obstructing the eject mech and this will indeed need to be repaired. I would suggest a local camera shop to look at the mech for you in this case. There is not really much you can do giving you tried several tapes but before making matters worse I would suggest a camera shop locally.
Thanks and please do be considerate if i where there it would be fixed but would cost you a lot more $$ then what you spent for my time emailing you. please do click the accept button for my efforts.
Posted on May 30, 2010
Sony High 8 Tape Older tape from periods 1993-1996
If you get in touch with a videographer I am sure they would have decks to try it out. Most of them are very nice and would not charge much. There are also companies that will do it for around 25$ a tape i believe.
If you need more assistance please let me know,
Lee
Jun 17, 2008 | Video Cameras
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
I have a Sony Video8 Handycam CCD-FX340 NTSC. It will not accept a tape. I can hit the eject button and the tape mechanism will come up and pop open. If I close it without a tape, it will go back down....
This problem can be caused by condensation. Leave camera and tapes in a warm dry place for a day and try again. If that doesn't help, there may be a tape threading fault. This can be something as simple as a broken drive belt, but still will require professional attention.
Oct 28, 2010 | Sony Video Cameras
I have an older camcorder that hasn't been used in a while. When I went to try to view the tapes made on the camera, I just get a blue screen with a white play arrow. The tape is moving inside though. It...
The video drum inside the tape mechanism consists of two sets of heads. One set for recording and one for playback. It's possible the playback heads are damaged, in which case the video drum will need to be replaced. It's also possible the video drum may simply be oxidized in and the camera only needs servicing and the drum deoxidized. I don't reccomend using "cleanning tapes" as they can sometimes do more harm thab good although you try. You might get lucky and this will solve your problem.
Aug 03, 2010 | Sony Handycam CCD-TRV68 Camcorder
GL2 is eating or damaging tapes.
Thgis is a fault in the tape transport mechanism.
It should go for service To open this and try a DIY may well result in it never going back togethyer again properly.
Thanks for using FIXYA
Sep 23, 2009 | Canon GL2 Mini DV Digital Camcorder
Lines in the screen
may be ur specific tape got fungus infected , have u tried several DV tapes if the result is same then u have to replace the head of ur camera which is offcourse expensive in service centre get a quote for that
Feb 20, 2009 | Nikon Coolpix 5700 Digital Camera
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Optura Pi is eating tapes
hi from what i understand by "eat" is that the coil is popped out what it means is that the coil leader is misplaced and letting it to run free out of place this can be fixed by you if you will find what had gone wrong in that path (broken pin, cog etc...) and glue it back or fix the missing element in place good luck
Apr 27, 2006 | Canon Optura Pi Mini DV Digital Camcorder
Canon ES900 Camcorder Logo
56 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
