Question about Thermos Stainless Steel Gas Grill
I have a Thermos 461262407 Propane Grill. It will not light, gets good ignition, and I just got a filled propane tank. I don't hear the sound of gas entering the tubes when I turn on the knob. Is it most likely a regulator problem (it has Marshall Gas Controls Model #150 regulator)? I couldn't find any blocked tubes or any sign of spider webs.
  • 494 Answers
Hello, here is a check list for your most common gas grill lighting problems: Hopefully one will solve it for you.
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. This is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scaleI have a Thermos 461262407 Propane Grill.  It will - 2_bing.gif. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve and let sit for a few minutes. Or just disconnect it and reconnect it. Turn the tank valve very slowly and then try lighting it again. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery2_bing.gif powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also spI have a Thermos 461262407 Propane Grill. It will - 2_bing.gifher it's natural gas2_bing.gif or propane.
5) If none of these resolve the issues you are having, it is also possible you have a faulty or defective regulator, which may mean replacement. If the pressure still seems too low and none of the above has helped, and you have a silver/gray regulator; many have an adjustment screw on the top center of the diaphragm. Remove the outer cap and turn the inside screw clockwise in 1/4 turns to increase the pressure until the desired flame size is accomplished. Flames should be as blue as possible, but will burn orange if there is food or drippings on it. Yellow flames are not good, and will soot up everything and not cook as hot as blue flames do. Yellow flames could mean you do not have the right air shutter adjustment, clogged burners, or possibly defective burners, as mentioned above in #4.
6) Also make sure you have the hose connection tightened snugly to the propane tank valve to ensure the inner valve seat is fully depressed allowing gas to exit fully without any restriction. The black plastic female fitting should be hand tightened only. Older versions that use a left-hand male brass POL valve, requires a 7/8 open end wrench or adjustable wrench to tighten.
Hope this helps! Good luck in your trouble shooting! Douglas
Posted on May 30, 2010
Why is my flame low and the others don't light
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jun 24, 2014 | Weber Spirit SP-310 Propane Grill
I have a only used 2x fire and ice. I have everything connected to a large propane tank. i can hear gas when i turn on but it will not light. what do or can i do.
shut off the propane tank and see if your regulator tube is blocked. If not blocked it could be that one has to have either regulators open to allow the gas to go through and wait for the count of 5 before hitting the ignite button.
Jun 09, 2012 | Thermos Grill2Go Fire+Ice
I have full propane, yet a low flame?
check the burners are not blocked and the orffice , check the reg on the tank giving full pressure
May 15, 2010 | Thermos Stainless Steel Gas Grill
We just got a new propane tank and connected it and propane is not coming through
I'll assume you had it purged of air before you had it filled, right? A full 20lb tank should weigh about 35-38 lbs. If so try this: Leave the tank valve closed for a few minutes. Then open the tank valve very slowly. It may have a built-in excess flow valve in the hose that is checking closed and preventing you from getting gas. See if that helps.
May 12, 2010 | Thermos QuickSet 462836203 (LP) Grill
I am not getting gas to the grill burners
Check out the reg could not be passing gas
Jul 05, 2017 | Thermos Stainless Steel Gas Grill
Flame not staying lit
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 28, 2010 | Thermos Grill2Go Gas Grill 4656110
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Cannot get ignition
http://www.charbroil.com/Consumer/ConsumerCreateCase.aspx
go to this link, fill in the info requested and a charbroil engineer will solve your problem for u. enjoy your grill. they are great when they work.
Nov 10, 2008 | Thermos Grill2Go Fire+Ice
Propane will not come thru burners
Most propane problems are due to a new valve on the top of the tank. It is designed to only allow a minimal flow until the line is pressured. This prevents fire flair up from broken or leaking hoses. Always turn the bottle on and wait before trying to light a burner. If the burner is on first, the propane will never come out at full flow or if you have a leak in the system, it won't pressurize sufficiently to allow full flow out of the bottle. There is never "air" in the tank.
May 28, 2008 | Coleman Roadtrip Grill LXE 9949-750
Thermos Stainless Steel Gas Grill Logo
666 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
