Question about Aroma ARC837 20Cup Rice Cooker
All the lights in my rice cooker are blinking. I can't get it to work anymore... what does it mean?
SOURCE: rice cooker vs a crocpot/slow cooker
I have both and use both for different things. The rice cooker cooks faster than the slow cooker. What the Crockpot does really well, the rice cooker cannot do. For example, with the crock pot, you can buy less expensive cuts of meat and because of the slow cook method, they will be tender, juicy, and delicious. You can make soups, stews and casseroles in a crock pot and the great thing is that you can turn it on low, go to work, and when you come home, dinner is done. You can cook the same types of things in a rice cooker but you can't leave it all day. You CAN saute', fry, etc,. in your rice cooker which you can't do in a crock pot but for dense veggies and tougher cuts of meat, stew beef for example, there's no comparison. I have an Oster Rice Cooker and Steamer which I use nearly every day. I cook rice, obviously, casseroles, veggies, spaghetti and meatballs, all kinds of side dishes and soups in it. I use the crockpot several times a week but more often in the Fall and Winter when I make soups, stews, chilis, roasts and BBQ. Oh my gosh, you have to try BBQ Ribs in the crock pot! They melt in your mouth. Go to Yahoo! Groups. You'll find all kinds of great info for both your rice cooker and crock pot. I have one of the fancier, more expensive crock pots because I take it to work with me one day a week for lunch. The lid seals and it comes with a carrier. If you do most of your cooking at home, you can spend a little less and get a good one. I recommend getting one that has at least 3 heat settings though. Different foods require different temps. Happy Cooking!
Posted on Nov 07, 2007
  • 41 Answers
SOURCE: Rice Cooker Instructions
if cooking rice is your problem. you must first fill your rice cooker with rice and rinse it with water to remove excess starch when your done removing the excess starch you will have to add water for every cup of rice, 1 1/2 cups water or you can try 1:2 ratio (1 cup of rice: 2 cups of water). same goes to any other cuisines. i hope you find my solution helpful.
Posted on Oct 07, 2008
  • 54 Answers
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
Posted on Jan 11, 2009
ginko
  • 19396 Answers
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
Posted on Feb 27, 2009
bayyagg
  • 1672 Answers
SOURCE: i have rice cooker i cant cook rice.i am on the
U mean, the rice cooker turns OFF after 5minutes?
Sounds like THERMAL adjustment needed!
Posted on Nov 07, 2010
I have s Sanyo ECJ-S35S rice cooker does not heat up. When I press Start/Cook button it keep flashing and light does not stay on. Any idea what I can do?
A rice cooker that doesn't cook anymore usually requires a thermal cutoff replaced. They act like a fuse and look like a resister. Look underneath it is crimped to one of the leads but perhaps underneath some braided insulation. Purchase another cutoff at an electronics components store (not radioshack). If there is not a rating on it try 185 degrees celcius.
Sep 22, 2013 | Sanyo ECJ-S35 3.5-Cup Rice Cooker
Aroma rice cooker ARC 978 - all control panel lights stay on when pluggged in. How do I reset??
Unplug the rice cooker and the remove the cooker kettle. Push the steel button in the center of the rice cooker to loosen the spring. Plug the rice cooker without the kettle, the cook function must not be functioning. Plug it again with the kettle and push the cook switch to see if it working properly.
Nov 08, 2010 | Aroma ARC7031G 6Cup Rice Cooker
Keep warn light is ok but cooker light doesn't work
check if there is a continuity of the cooker light by using vom tester, if there is a continuity it means the cooker light is ok. also check the connection maybe it is loose..
Aug 31, 2010 | Panasonic Kitchen Appliances - Others
The Rice master RC12 issue 1/01 has lost the teflonfromthe bowl and I wonder where to get a new bowl.
you cant , no parts made for this cooker . try to not use this cooker anymore untill you get it replaced , the teflon is bad for your health if you eat it ....... enjoy your new cooker
Nov 05, 2008 | Breville RC16XL 6-Cup Rice Cooker
Betty Crocker rice cooker
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Sep 30, 2008 | Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Rice cooker stopped working after one month's use
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
Nov 12, 2007 | Panasonic SR-SH15PS 8-Cup Rice Cooker
Aroma ARC837 20Cup Rice Cooker Logo
194 people viewed this question
Top Aroma Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
