Question about Pool & Spa
How to check oil level on a 1953framall super a
How to check oil level on a 1953 framall super a
  • 2,841 Answers
It holds 6 quarts of oil. You really need a shop manual for your Famall Super A.You can get one here: http://www.amazon.com/exec/obidos/ASIN/0872881016/tractordata-20 Here is some more information on your tractor. http://www.tractordata.com/farm-tractors/000/2/9/292-farmall-super-a.html
Posted on May 30, 2010
Eng.oil light comes on and off at low idle, goes out when rpm increased.
Have to ask, have you checked oil level?
Could be old oil....has the oil been changed regularly?
If level ok then check oil pressure switch or oil pump for fault!
Aug 08, 2015 | 2002 Harley Davidson FXD Dyna Super Glide
Supermagna oil check
There is a small window on the side of the crankcase you look at to check oil level.
Apr 07, 2014 | 1988 Honda VF 750 C Super magna
HOW MANY QUARTS OF ENGINE OIL ARE REQUIRED FOR A 2004 HARLEY DAVIDSON DYNA SUPERGLIDE WITH OIL FILTER CHANGE
Three quarts. Check the oil level with the dipstick once finished changing the oil. There are two marks on the stick. The upper mark is "FULL HOT" and the lower mark is "FULL COLD". Keep the oil level between the two marks. Do not overfill.
Good Luck
Steve
Jun 28, 2011 | 2004 Harley Davidson FXDX - FXDXI Dyna...
Just bought 2003 super glide where do check the oil
Look on the left side ot bike as you are sitting on it, at the rear of the motor there will be a large nut like plug at the rear of motor will look like it is on the Transmission. check the oil level while on the Kick stand and engine warm.
Nov 15, 2010 | 2003 Harley Davidson FXDX Dyna Super Glide...
I just bought a 2003 Super Glide and want to know where the "dipstick" to check the oil is located!
Since the oil tank for the engine is on the bottom of the transmission, the dipstick of the engine oil is on the large round cap where you add the oil to the tank on the right side of the bike on the corner of the transmission.
It has two marks on it, "Full Hot" and "Full Cold". Keep the oil level between the two marks. Do not overfill.
Good Luck
Steve
Sep 26, 2010 | 2003 Harley Davidson FXD Dyna Super Glide
How much oil goes in the transmission of a 2008 super glide.
20-24 ounces and then check the level with the bike standing straight up with the dipstick. The oil level must be between the two marks, Do not overfill.
Steve
Sep 02, 2010 | 2006 Harley Davidson FXDI Dyna Super Glide
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
Want to check the oil level in differenial,is the bottom plug to drain and the top is the to add and level gauge.thanks
remove the top fill plug and on level ground, stick your finger in the hole. the level should be 1/2" from the top of the hole
Apr 11, 2010 | 2001 Ford F250 Super Duty Super Cab
My 1953 (the year 1953) Dayton 5K683 electic motor smokes when plugged in if there is any load (like like the belt connecting it to the table saw blade.) I know my father never oiled it. Does it just need...
you dont oil electric motors if it is smoking then it is burning out ,take it off and take it to amotor rewinder they can test it before starting the job but i must say that 56 years is a good run out of anything.my missus is starting to wear out and i`v only had her for 45 years .
Sep 05, 2009 | Air Tools & Compressors
1995 ford powerstroke
Try wd 40 to start it ,sounds like the piston rings are dry
Nov 14, 2008 | 1999 Ford Super Duty F 550
Pool & Spa Logo
192 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
