Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Won't turn over
Battery is charged and when I turn the key, it won't even click or start to turn over. Where is the best place to start. It started just moments before this problem surfaced
    Problem Solver:
  • 11 Answers
Move the ignition switch connector around a little bit some times they get wet and after time stop working
Posted on May 31, 2010
My car will not start. The battery is new and has a full charge and turns everything on when I turn the key but when I try to start it, it will not do anything not even clicking noise.
if the battery is good it is NOT the alternator. the alternator charges the battery, if it won`t start with a new battery the alternator does nothing to affect the situation. check voltages at the starter motor connections for proper voltages even the wires that the ignition switch supplies power to. if you have proper voltages at the starter you can try hitting the starter while someone tries to start the car. if it starts the starter is worn internally and will have to be replaced.
Aug 05, 2015 | 2003 Hyundai Santa Fe
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
Nov 12, 2012 | Cars & Trucks
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
2005 Charger won't start, put key in , turn the key and all I get is dash board light and radio but no turn over ! Just nothin' , no click ! Nothing !
sounds like a flat battery but it could be a wire off the starter motor solonoid even a immobilisor problem but the most obvious is a flat battery try charging it up for a day then try it before you go any further
Jun 07, 2011 | Dodge Charger Cars & Trucks
Sprayed down lawnmower with water, now it won't start. I decided to "wash" the lawnmower last week and now it won't start. And the really weird part is the solenoid clicks every minute...
Engine will not run with no spark or a weak spark. Continuity test will only reveal that the winding is not open, not if you are producing a weak spark that will not jump the spark plug gap.
Mar 31, 2017 | Garden
Won,t start, acts like no juice is going to starter w/charged bat
You need to have your Battery Checked. Common Symtom of an Early Failing Battery. Not enough Cold Cranking Amps Left to Kick it over.
Jan 12, 2009 | 2006 Honda Pilot
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
61 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
