Question about Canon SmartBase MP390 All-In-One InkJet Printer
Print head replaced still no black printing
Hi, i've undertaken the following procedures on my Smartbase 390 to try and get the black to print:
- replaced both black and colour cartridges
- made sure they are securely in place
- then purchased new and replaced printhead
But still the black doesn't print! Please help.
Thanks
PS
  • 1 more comment
  • Carpe Diem7 Apr 09, 2008
    Just undertaking 5 head cleanings and now it's just the blue printing. Thanks for the suggestion though - worth a try.
  • Dugald Apr 23, 2008
    Replaced Black cartridge but still no black printing - can I clean the print head mechanism ?
  • bascom Jul 10, 2008
    I have replaced the black cartridge and no black ink printed however it seems to work if i go into properties and chnage the type of paper to photo or matte photo finish howecer it prints much slowly.Any help to get this fixed?
Do 5 deep print head cleanings
Posted on Apr 08, 2008
It doesn't print in black but prints in color
Hi, To ensure this is only an issue with the black, I recommend printing off a nozzle check. This will show you if this problem is effecting any of the other colours.
To print a nozzle please refer to chapter 12 page 115 of the manual,
If colours are missing I recommend cleaning the print head. You have two options for cleaning the print head a normal clean and a deep clean, start by doing a normal clean if required try doing a deep clean.
You can download the manual here:
http://www.fixya.com/support/p360568-canon_multipass_mp390_all_in_one_inkjet/manual-10203#
Dec 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Black will print properly only on "High" Print setting
After all the trouble shooting you have done their most likely a hardware issues causing the problem.
Please Contact Canon for repair service or replacement.
1-800-828-4040
Nov 14, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
I have replaced the black but it still won't print
You have a clogged print head.Try with "cleaning" or "deep cleaning" test, you find it in "maintenance" menu.If not help you need to replace the print head.It's part number is QY6-0037.
Oct 09, 2009 | Canon Office Equipment & Supplies
Not printing in black
Replace the ink with a new one. Can be the black ink was empty or dried out and not produce black. Or you may try a print head cleaning sometimes the print nozzle was clogged.
Hope this helps.
Aug 16, 2009 | Canon SmartBase MP390 All-In-One InkJet...
The printer goes in motion to print but doesn't print anything.
hi
have you tried cleaning the print head? clean it by rubbing the contacts of print head and cartridges with alcohol which should sokve the problem due to clogging or blocking.
you can also use the print head cleaning software to help you.
cheers
Jul 26, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Won't print anything in black new ink
clean contacts on print cartridge and print head with alcohol
Jul 10, 2009 | Canon SmartBase MP360 All-In-One InkJet...
No printout showing (offline)
If printer wasn't used much before you got it I would suggest that the heads are blocked. My experience with Canon Smartbase printers is they block easily. Try to soak the head in warm water or use an ultrasonic bath to clean out the head and see what happens.
Oct 20, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Aug 13, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Printer Problem
Hello Dear,
The nozzles of the print head are jammed. you can try this take about 50 ml of luke warm water (please ensure that the temperature of the water is not too high as it may spoil the print head physically) in a small flat base dish and keep the print head in it (only the bottom part the nozzles should be dipped and not the green circuit chip) for about 30-40 minutes there are about 40% chances of print head recovery, if this solves your problem them its ok or you have to purchase a new Print Head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Mar 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Canon smartbase mp730
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
Nov 26, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Canon SmartBase MP390 All-In-One InkJet Printer Logo
182 people viewed this question
old marine
old marine
Corne Viljoen
