Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
I have an LG dishwasher stopped with IE error message.
Hi there, I have an LG dishwasher which stopped mid-cycle with an IE error message. Dishwasher is approx 2 years old. Have tried turning it off and starting it again only to have the same IE message come up, this time about 2 mins in to the cycle. Have checked, and there is nothing clogging all of the obvious areas. Any suggestions please? KP
  • 523 Answers
Ie means water
le is pump bad
Posted on May 30, 2010
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Lg dishwasher stops throughout the full cycle
If you are still having problems with your LG dishwasher, turn off the hot water supply to the dishwasher and remove the hot water inlet pipe (remove the lower, front panel (toe kick plate) )
Check the screen/filter at the water inlet on the dishwasher.
Reconnect the pipe and turn the hot water supply back on.
Test out and enjoy!
Apr 01, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
LG Dishwasher Model LD-14AW3
I have had this dishwasher about 4 years, it has work beautifully, then one day there just wasn't any power going to it. Have tried different power points and no change. Looked for a fuse, was unable to find one. The power cord coming into the machine is undamaged. Any suggestions.
Mar 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
974 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
