Question about Dishwashers
Hey all, my dishlex dx302 wont heat the water thereforgiving a **** clean. Have searched this topic for a solution and after removing circuit board from front door i found that the board doesnt seem to have dried out like the pics show in some instance any other ideas
  • Dishwashers Master
  • 43,501 Answers
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
I have a electrolux dishlex dx302 that will not heat the water and dry ,how dose it work?
Yes I had the same problem. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Jun 29, 2009 | Electrolux Dishwashers
Dishlex 302 water not heating
My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
Jun 26, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
My DX302 dishwasher wont heat the water, the heating element is ok.
Yes I had the same problem with the DX302. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Worked for me.
All the best......
Jun 22, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Water not getting hot
there is no thermostat but there is a temp sensor (ntc probe). if you check the Resistance between terminal g5 and g6 you should get 6.03 k ohm at 20 degrese Celsius.
it sounds to me like the control board needs replacing.
i can send you a wiring diagram and full diagnostics in pdf format if you give me an email address
Feb 20, 2008 | Dishwashers
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Dishwashers Logo
751 people viewed this question
Top Dishwashers Experts
