Question about Brother MFC-8660DN All-In-One Laser Printer
Where can I find instructions on how to replace PF KIT1 (on 8660DN brother MFC printer). LCD displays the message asking to replace PF KIT1. I went thru this site and followed instructions on how to clear the message but it did not help. I believe this is a real issue because the printer makes a strange sound whenever I try to print (like some gears slipping) and obviously it does not print anything. I have already purchased the replacement kit but have no idea how to fix it - would appreciate any pointers, instructions or help thanks
  • averma00 May 30, 2010
    Thank you for the response. Yes I did come across this document when doing google search but it was not very helpful. I was hoping for some printer specific instructions or pointers
    thanks
  • 4,924 Answers
Http://solutions.brother.com/Library/pdf/pfkit_hl6050.pdf
try to follow this instructions ...if they are not from the same type ...at least will give you an idea...
Posted on May 30, 2010
Testimonial: "I appreciate your help and I apologize for the earlier rating - I am new to this site and am not familiar with all aspects of the rating system. I any case, I went back to the link you posted and although my printer is different I was somehow able to replace the PF kit. So thanks a lot for your help"
  • Catalin Turcu
    Catalin Turcu May 30, 2010
    well done...you finally made me realize that I will have to never take free problems anymore...not just that I got the problem free and all but I don't realize what help was for you or inconvenient to rate me in such a way ...this s....vote will affect me for at least 10 ones for people that I will help...and it made you no difference ..at least you should know better from now on and do not s...t people that try to help you ...I guess voting will keep you worm tonight ..Have a beautiful life!...
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Nov 26, 2014 | Brother MFC-8370DN Laser Multifunction...
Brother 9970cdw toner
The Brother printers have a counter which will shut the printer down when the preset number of copies has been reached. You can reset the counter and it should print again. I did this 4 months ago. It bought me a little time, but my printer has begun to print a solid line down the left side of each page. I have cleaned everything that I can access to rule out smudged glass, etc. Perhaps it is just best to replace the drum or buy a new printer(much to Brother's delight and design).
Jul 10, 2012 | Brother MFC 7420 All-In-One Laser Printer
REPLACE PF KIT1
THIS IS HOW YOU WILL RESOLVE YOUR ISSUE OF REPLACE PF KIT1 ON UR Brother MFC-8460N All-In-One Printer
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer
THIS WILL DEFINATELY RESOLVE THE ISSUE
REPLACE PF KIT1 : THIS IS IN REGARDS TO THE MAINTENACE DISPLAY THAT YOU HAVE ON YOUR PRINTER
TAKE CARE AND HAVE A NICE DAY..
Jun 22, 2010 | Brother MFC-8460N All-In-One Printer
REPLACE PF KIT 1 MESSAGE ON DISPLAY
solutions.brother.com/Library/pdf/pfkit_hl6050.pdf -
The above link will show you how.
Mar 30, 2010 | Brother MFC-8460N All-In-One Printer
Will not feed paper
Replace the paper feeding (PF) kit and the fuser. Instructions on how to do so maybe found on this manual.
Mar 24, 2009 | Brother MFC-8460N All-In-One Printer
Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Nov 21, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-8660DN All-In-One Laser Printer Logo
1,360 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
