Question about Video Cameras
How do you format a mini dvd - Video Cameras
  • gangemidance May 30, 2010
    Sorry but I need to know how to format a mini dvd for a camcorder as it asks you to do thqt before you start recording?
  • Video Cameras Master
  • 4,924 Answers
If you are talking about the inside memory you have to access the main menu than look for the storage settings ...there you will have choises for internal and card ..choose internal and see the options for to format..or if you want to format the card ..choose the card and also ..options or unfold the features and choose format ..
Posted on May 30, 2010
  • Catalin Turcu
    Catalin Turcu May 30, 2010
    this is asked for special mini dvd rewritable for cameras...and you just do the same ...insert it ..choose from the menu the format dvd and just do it ...Iti is the procedure that makes it suitable to use in the dvd camera for shooting ..do not forget that when you finish the shooting ..you will have to finalize the disk in the camera using the finalizing feature ..for make it usable in other players..so that you will be able to copy and edit it ..
    So in sort ...insert it ..and look in the menu for format dvd..feature..
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
Jul 25, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Tip
How to rip commercial DVDs on Mac - for playback on wide screen TV via WD TV...
How to rip commercial DVDs on Mac - for playback on wide screen TV via WD TV Mini
WD TV Mini Media Player supports up to 1080i resolution for crisp HD media playback, besides this feature, it will never limit the size of your media collection, and you just need add more drives as you like. However there is no luck with commercial DVDs, even though you need not consider about the storage space, because these DVDs have strict copy protections, which WD TV Mini is unable to decrypt. To rip commercial DVDs to a compatible format with WD TV Mini on your Mac, what you will need is Pavtube DVD Ripper for Mac only. Go to find a step-by-step instruction as below.
First off, have a look at WD TV Mini Media Player supported media formats:
Videos:
AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10
Audios:
MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, OGG, APE
You can free download Pavtube DVD Ripper for Mac here.
Step 1: Launch Pavtube DVD Ripper for Mac, and load DVD files to it
You can click "DVD folder" or "IFO file" to load DVD files directly from the DVD-Rom, DVD folder, or from an IFO image file.
Step 2: Select an output format for WD TV Mini Media Player
Click on the pull down menu of "Format" to a WD TV Mini Media Player supported format as output format. Here I select "Xvid AVI" as my choice.
Step 3: Set advanced settings
Click on "Settings" button, and you are allowed to adjust audio and video parameters on the popup window including codec, bit rate, frame rate, sample rate, aspect ratio, and audio channels. The user manual of WD TV Min tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD.
Step 4: Set destination folder
Click "Browse" button to specify where to export the output files to.
Step 5: Click "Convert" button to start ripping DVD
The following window will show you clearly about the ripping info, such as time elapse, estimated left time, generated file size, and estimated file size. In that way, you are able to manage your time and storage space in a proper way.
Once ripping work is done, you can click "Open" button to get the output files for WD TV Mini effortlessly.
Additional tips:
1. The ripping speed of this software is 1-2 times faster than the similar programs. Merge multiple files into one file is available.
2. Enable users to select specific subtitle and audio track to convert.
3. Guarantee audio-video in sync.
4. With exception of adding text as watermark, images, GIF animations, and videos can also be added as watermarks to realize the picture-in-picture effect.
5. You can use the "Trim" function to select certain DVD clips to convert. And you can also take advantage of the "Crop" function to remove black edges or change the screen size.
on Apr 09, 2010 | Audio Players & Recorders
Tip
Videos:
Audios:
Additional tips:
For more: http://www.pavtube.com/dvd-ripper-mac/
on Mar 31, 2010 | Audio Players & Recorders
Read mini dvd's
If it is capable of reading DVD-R or DVD+R look at your manual it will tell you what formats it will take.
Dec 17, 2008 | Sony DVP-NS55P DVD Player
Tip
How to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player
WD TV Mini Media Player provides an easy and affordable way to play back your digital media on your wide screen TV.  It serves as a conduit between your TV set and USB drive storage, no matter it is a camcorder, a humble flash drive, or an external HDD. Simply connect WD TV Mini to your TV, plug a USB-connected storage into the player and you are ready to enjoy all your digital media in DVD quality playback.
Videos:
Audios:
From the above list we can see that VOB is a playable format for WD TV Mini Media Player, does it mean that WD TV Mini can play all kinds of DVDs – whether home made DVDs or commercial DVDs? The answer is WD TV can not decrypt copy protected commercial DVDs, so you have to rip them. This tutorial aims to show you how to make it possible for you to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player. What you will need is Pavtube DVD Ripper, it not only rips, but it encodes too. Following is the detailed operating steps:
Step 1: Click "DVD Rom", "DVD Folder" or "IFO/ISO" to load DVD files into this program.
Step 2: Select subtitle and audio track
Click on the pull down menu of "Subtitle" and "Audio" respectively to select your needed subtitle and audio language.
Step 3: Select output format for WD TV Mini Media Player
Click on the drop-down list at the end of "Format" to choose an output format for WD TV Mini Media Player. Your selection should be in the range of AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10. Here I select "Xvid AVI" as an example:
Step 4: Click "Settings" button to adjust video and audio parameters
The user manual tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD.
Step 5: Click "Convert" button to start DVD ripping
Once finished, you can get the generated files for WD TV Mini via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV Mini to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your commercial DVDs.
For more: http://www.pavtube.com/dvd_ripper
on Mar 29, 2010 | Audio Players & Recorders
Tip
Experience Blu-ray and DVD movies on HTC HD mini
At the Mobile World Congress in Barcelona, HTC unveiled the HD mini which is running on windows mobile 6.5.3. Clean lines, compact form, and elegant construction give the HTC HD mini the looks that fit any place, time or circumstance. It features shortcuts to important people, web sites or application, kinds of social networking, business E-mail, animated weather wallpaper, adjusting ringer volume automatically, 5 megapixel color camera, etc. HTC is committing to offer the best user experience for customers, and the multimedia function is no exception. The 3.2in AMOLED capacitive display, effective resolution of 480×320, superb contrast and colour rendition will enable customers to have the best experience in enjoying movies on HD mini.
Blu-ray and DVD movies are very popular HD movies nowadays, most of you, must like me, wanna watch Blu-ray and DVD movies on the impressive HD mini. OK, let’s see how.
First, we need to know:
Audio supported formats:
aac, .amr, .m4a, .mid, .mp3, .mp4, .qcp, .wav, .wma
Video supported formats:
wmv, .asf, .mp4, .3gp, .3g2, .m4v, .avi
Then, what we need to use:
Pavtube Blu-ray Ripper
Step-by-step tutorial is listed here:
Step 1: Click “DVD Rom”, “DVD Folder” or “IFO/ISO” to import your DVD files.
Step 2: Click the drop-down list of the format to select the suitable format
Here I choose MP4 format, cause this format will save your space and keep high quality.
Step 3: Click “Setting” button to do optimal setting
Because N97 has 480X320 pixels, to watch videos in full screen, we’d better set the aspect ratio at 480X320. Here are my settings - full screen, good quality and sounds well:
Video Resolution: 480*320
Video Bitrate: 768 kbps
Audio Bitrate: 128 kbps
Video Format: MP4
Audio Format: AAC
Frame rate: 30fps
Sample rate: 44100hz
Audio Channels: 2 Channels
Step 4: Click "Convert" button to start conversion
Once all the conversion is done, you can get the output files via clicking "Open" button. Then, you can enjoy the converted files on your HD mini effortlessly. Good luck.
For more: http://www.pavtube.com/blu-ray-ripper/
on Feb 25, 2010 | Cell Phones
My emachine will not read mini dvd,s
If you mean a mini dvd from a camcorder, your computer may not be able to read that particular video format. Will the mini dvd work in a different computer? Have you ever been able to read a mini dvd before?
Oct 12, 2008 | E-Machines eMachines Desktop PC
Maddog MegaSTOR 18X Triple Format External DVD-RW Burner
Kill that Mad Dog. Otherwise you will get mad soon.
Apr 02, 2017 | Televison & Video
Mini dvd can be burned on a regular dvd, but cannot be played
convert them to normal format using file convertor or record in VR format instead of Video format
Oct 24, 2007 | Canon DC210 DVD Camcorder
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
