Question about HP 2009M Monitor
Monitor going to sleep problem
HP 2009m monitor is at the "monitor going to sleep" and I can't seem to get out of that mode. I have tried unplugging and replugging the moritor to the tower and the power supply as well as holding down the on/off button on the monitor for 20-30 seconds. any suggestions?
    Genius:
  • 1,189 Answers
  • Hi, The Monitor as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. If this solution to the problem was of help? Let me know by giving a "Helpful Rating", thanks, and have a "Great Memorial Day!"
Posted on May 30, 2010
  • paul7of9
    paul7of9 May 31, 2010
    Hi, I see at least (20) twenty people viewed the solution. "My question is did it help any of you?"
  • paul7of9
    paul7of9 Jun 02, 2010
    "Its kind of hard to understand that a solution can be "Rated" somewhat helpful, when I know for a "FACT that if this solution is applied; there is NO! way its not going to work. It goes against physics."
    New Friend:
U cant search without monitor to on.
Posted on Jun 11, 2015
Well when My HP Monitor goes to sleep I just press ESC up in the top left hand corner. Then my monitor wakes up straight away.
Posted on Jun 02, 2010
  • xRaidOne Jun 03, 2011
    My ESC key broke at the time this happened. And when I unplug the blue cord (DVI or something) it says "No Signal" but then when I plug it back in, it says "Monitor going to sleep", by the way I'm using 2009f monitor. At the time this happened I was watching a movie online then the computer froze so I pressed the power button on my computer to forcefully shut it down. When I turned it back on, that's when the problem occurred. Any help here?
  • Teresa Dec 06, 2012
    i have a 2009m model and it goes to sleep a few seconds after I turn it on so I am unable to go into any setttings to change it. Any suggestions?
Monitor won,t wake up from sleep mode
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 20, 2014 | HP 2009M Monitor
I have a hp 2009m monitor and i want to connect it to an emachines t6212
Verify you have connected the VGA cable to the VGA output of the computer.
Feb 05, 2013 | HP 2009M Monitor
HP 2009m LCD monitor is cracked.
I would buy a new monitor. Unless you have some prior experience with replacing screens, the labor outweighs the price of a new monitor.
Dec 26, 2012 | HP 2009M Monitor
When it goes to s;eep and i try to bring it back
you are using pirated latest version. this is a problem of drivers only either download drivers from http://www.vistaheads.com/forums/register.php or use the older version of operating system
Apr 12, 2010 | HP 2009M Monitor
Monitor reading power lockout when try to shut off
the PC never turns off power to the monitor, it has its own power.
and sure, the monitors all do that 2004 to now. called VISA sleep.
modem has nothing to do with this.
Some monitors have this features called that.
its in your users manual. 2009m?
your page.
https://support.hp.com/us-en/product/hp-value-20-inch-displays/7274733/model/3884700/manuals
the words are clear.
it has power saver mode, turn that off
it has osd LOCK,
but no powerlock. as some do,. as your manual. shows.
page 24 shows.
http://h10032.www1.hp.com/ctg/Manual/c01725831
quote, power button does this.
turns the monitor on and to standby or sleep mode.NOTE:
The power button is located on the top or front of the monitor depending on the model
off , on, and sleep.
my guess you are putting the power button i Sleep mode
a feature of this monitor.
Aug 24, 2017 | HP 2009M Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
My HP FL523H monitor is locked in the sleep mode
Hi...there,
Could it be your backlight inverter it burnt out... cuz there no sleep mode in the LCD monitor.
Nov 12, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP 2009M Monitor Logo
4,371 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
