Question about Turboair TAS-24H Split System Air Conditioner
Air conditioner turns on, runs for a bit, then shuts down.
Temp set at 69, room temp is currently 82... units vents closed, green light flashes just as it always does. I have cleaned the filters, tried the power down wait power back up, nothing is helping
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
New lg window type without remote ,when you run it for one hour there be excessive ice formation
You MIGHT see a bit of ice form when you first turn a unit on asp if the humidity is a bit high. check the filter and make certain it is not covered with a peice of shipping material. all so you might want to close any outside vents or fresh air vents that might be open. close off all rooms that are not in use. set the control to a mid point and give the unit time to cool the room down. 70-74 is a good temp .. Let me know if the helps Jon
Aug 07, 2011 | LG Heating & Cooling
Room is warm 86 deg. unit runs, discharge temp is near 70 deg. unit runs for a while, will not bring room temp down.outside unit shuts off, i turn unit off, 1 hour and restart, it does the same.
The unit has a leak and is low on charge (freon) Find and fix leak, then vacuum and recharge...Leak is probably in flare fittings behind unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Mitsubishi MS24WN Air Conditioner
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
GE AGM08LJG1 window unit: digital temp increases on its own. Ex: when set to 65 degrees (and timer set to turn the unit off in 4 hours), return to the room 2 hrs later and the digital temp reads 69. What...
its telling you the room temp that is been sucked into the evaporator.its normal for this to happen.once you set the temp you want.it stays there untile you change it.but its all good.
Jun 09, 2009 | GE Deluxe AGM08LJ Thru-Wall/Window Air...
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Room temperature has not changed since hooking up new portable a/c
This may sound dumb but ( 1) Do you have the warm air from the unit to the exterior of the space? If the condenser is in the space your putting the heat your trying to remove right back into the space. ( 2 ) There should be an air supply and an air return in the space only. With that there should be a temperature difference of 16 to 20 degrees between the supply and return. ( 3 )A 1 ton unit usually will cool approximately 400 square feet. ( 4 ) It may take a while to pull the space temp down due to pulling the heat and moisture from the ceiling, walls, and floor. This could take 6 hours or more the first time you use the system in a space.
Turboair TAS-24H Split System Air Conditioner Logo
26 people viewed this question
Top Turboair Heating & Cooling Experts
Steve F
Darial Jr Lasaria
Darial Jr Lasaria
Tom Chichester
Are you a Turboair Heating and Cooling Expert? Answer questions, earn points and help others
