Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
The pump runs but the water is not flowing in my Oasis spa tub
  • 8,404 Answers
Your impeller has spun the center out of it. Remove the pump and replace the impeller.
Posted on May 30, 2010
I just hooked up a used Oasis II caldera spa. The high speed mode for the jet pump is not very high. Is there any way to get more power? Or is it hooked up wrong?
Hi Terry before you look at issues with the pump make sure the jets are fully opened where you want the power, and close or partially close the jets that you are not using which will add more power to the jets you are using. By turning the jets clockwise and counter clockwise you can increase and decrease the water flow at each jet. There also maybe a diverter valve that sends the water to different sections of the tub. Lastly open up the air intakes this will give you more water displacement. Hope this helps.
Jan 23, 2015 | Pool & Spa
OH code for x500 how to repair?
if water flowing possible bad temp sensor or recirculation pump running too slow
Jun 13, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Hydropool hot tub
Check your filter. It may be clogged. This will restrict flow and prevent the pressure/flow switch from actuating. The heater will think that water is not flowing and not allow the burner to produce heat.
Jan 31, 2014 | Pool & Spa
Display on hot tub says low flow
Low flow is an indication of not enough water flowing through the system.
Check the flow by removing the filter from the spa and see what that does for you. Many times even brand new filters have enough tiny fibers from the manufacturing process to not let enough water flow through to operate a spa.
If you remove the filter and it still has a flow issue then make sure the gate valves on either side of the pump are completely open and no restrictions.
Also make sure the water is full in the spa.
Rod
US Parts Center
888-521-6183
Feb 15, 2013 | Pool & Spa
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
We have a brand new Oasis Mohave spa and we wanted to run through a full cycle so we ran the tub for a week, no problems. then we drained and refilled the tub. Now we get dr or dy as error codes on the...
The dr error code is for "dry". Meaning that the control system is not sensing that water is flowing through the heating element.
With a new spa, and you just having drained it , it is probably an air locked pump.
What this means is that you have a small constant circulation pump with not much power, that got ait trapped in it when you drained. When you went to start back up, this "air lock" prevented the pump from fully priming.
Power down the spa at the breaker. Remove the filter element.Stick a garden hose with lots of pressure into the skimmer hole and open the hose valve to let water inject into the skimmer.
Restore power to the spa and check operation.
If after attempting this a few times you still get the code, there is an issue with your flowswitch, or with your circulation pump.
With a brand new spa, id like to hope that you just have an air lock.
Good luck
Mar 16, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
174 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
