Question about Shuttle SD37P2 V2 (SD37-P2-BK-V2) Barebone
IT TRIES TO POWER UP THE FANS TURN FOR A WHILE THEN IT SHUTS DOWN
Turn off the monitor before pressing the power button, if the doesn't work, try unplugging the monitor completely before pressing the power button.
Posted on Nov 13, 2010
My Dayton heater will not fire up and tries to fire and then shuts down tries to fire and shuts down blows smoke out the end
Check noggle for dirt, check fuel filter for dirt. Check al rubber hoses for leaks, Set air pressure All these will cause it not fire.
Dec 28, 2014 | Dayton Heating & Cooling
NEC LCD1760V shuts power down after 3seconds
Hi Ron usually power down issues are caused by faulty power supplies especially if the projector looses power completely however the logic board could be protecting itself if it detects a fault such as a fan not working either way it is not recommended that you try to fix it yourself unless you know what you are doing, but it may be worth removing the cover and checking that the fans are working and connected properly, occasionally the lamp can be at fault especially if it has been used for many hours if the projector tries to power up and you see light through the lens and then it looses power its probably the psu at fault, if it powers up then goes into standby of fault then its most likely a logic issue. I hope this helps Regards Ant
Nov 30, 2011 | NEC Office Equipment & Supplies
Sony kp-65w5510 rear projection tv power button malfuction
Replace bulb and clean cooling fans of dust is the first thing to do. if that doesnt work might start checking capacitors on the power supply.
May 10, 2010 | Sony KP-65WS510 65" Rear Projection...
Hp Pavillion powers up then shuts down
this usually means that theres a hardware problem. its possible that you could have short-circuited a device from ESD when you changed your DC jack. always remember, before you take apart your computer, even as symple as swapping RAM, disconnect the power cord, remove the battery, and press and hold the power button for 10 seconds to clear the sensitive circuitry of any remaining juice. if you have the BIOS beeps disabled (as they are default in most newer systems) then you have a real problem. try to listen for the fans to kick on and the hard drive to kick up. if everything sounds ok, then it might be the videocard or the ram. usually, from my past experience, its the processor that has burnt out. but then again, im an overclocker.
Jan 06, 2010 | HP Computers & Internet
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
The fans no longer turn on and the inverter shuts
YOu can replace the small fans and it will work fine. Go to newark,com and they have very small cooling fans like that.Same ones that computers have for cooling. You will have to open things up and get some numbers and dimensions.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | RoadPro Electronics - Others
Samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
Oct 17, 2008 | Samsung HCM4215W 42" Rear Projection...
Christie Roadrunner 100
check to see if the fans are moving. if not, replace the fans. if the fans don't come up, the projector shuts down to protect the circuitry and the lamp. if the fans are fine, most likely the power supply/ballast is not producing enough power to keep the lamp lit and shuts down.
Aug 14, 2008 | Christie LX45 Multimedia Projector
Shuttle SD37P2 V2 (SD37-P2-BK-V2) Barebone Logo
113 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
