Question about Health & Beauty
New brake put on about 1 year ago. now doing the same things. very slow foreward and reverse. causes batterys to loose power fast. Batterys new. The scooter is a mm-222 by mega motion
  • 177 Answers
Hi. If you manually release the brake ( free-wheel ) can you push the scooter by hand across the floor?
It might not be the brake. Check the resistance through the brake coil, it should be about 50 ohm's.
It is possible that the motor has burnt out, this could cause the same fault that you have. A burnt out motor has a very distinctive smell of burnt varnish.
Good luck. Neil.
Posted on Jun 01, 2010
I have a 2005 Mercury Mountaineer. Most of the time when I put it into reverse, the engine cuts off or sputters like it's going to cut of. The transmission was replaced 1 year ago.
Only in reverse? May have a shift solinoid issues or something related to it. You will need an experienced tech to do a scan check to see if any of the sensors or solinoids are out of range or slow acting as you may not get the bad code to come out rightaway but it causes durability issues and having the right experienced teck that knows how it works it will save you headaches and $$ in the long run. Also another thing that comes to mind is a possible vacuum leak from your brake booster and tgat is something you can check at home without a scanner. With a long needle vicegrips reach over and squeeze the big vacuum hose going to the booster letterly plugging the pass of vacuum inside. Very carefully start the car, apply the brake pedal and you will notice that they are stiff, then put it in reverse and see if does the same thing. If that fixes it then you have a bad brake booster, if it doesnt help any then your problem is elsewhere. DO NOT LEAVE THE VICEGRIPS ON THAT HOSE it will make the pedal very stiff and it wont want to stop which can lead you to have an accident.
Dec 12, 2014 | 2005 Mercury Mountaineer
Power wheelchair gearbox slips going uphill
that can be caused by several things,low voltage, gearbox has a broken tooth in gear ,or u may need to buy new batterys, have some one check voltage of batterys first, and have them do a load test on batterys also,good luck and if this seems be ok have a dealer tech look at it and tell u what is wrong
Dec 04, 2013 | Jet 3 Ultra Power Chair
I have a metro 500 and it is about 14Yrs old i never had a problem. After i put the new batterys some thing went wrong with the cnnector cable . My batterys are fully charge but on the joy stick within 15...
loose connection on battery? if new batts then you must charge them for a full 24 - 48 hours before using. but posts must be tight. they never fully charged if connections were loose to start check all connections on chair
Oct 27, 2012 | Everest & Jennings Health & Beauty
My scooter is too slow,the battery charges,but it only drives at very slow speed,while going backwards it goes fast.Can you tell me what to do?
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. In the future give as much info about the scooter as possible.
1. Replace the throttle pot and or the speed pot.
2. Sometimes even batteries that take a charge are not strong enough to run the scooter. Have them load tested at an auto parts store to make sure. If you have bad batteries that will make you scooter do what you say it's doing. Don't forget your reverse speed is only 1/2 as fast as the forward speed on all scooters.
Good Luck
Tim
Apr 30, 2011 | Health & Beauty
I barley ever use my kodak camera sine christmas like 2 years ago and i have enigizer bunny bateries in it and i dont know if it hasd a charger but i need help cause the screen turns black whenever i use...
While let's start here if you rarely use it please don't leave batterys in it as they will rust and pop open. Batterys have acid in them and will cause a bad connecting when installing new ones. Are the batterys rechargeable or just regular batterys if so I would start there.
Apr 28, 2011 | Kodak EasyShare Z1012 IS Digital Camera
My husband has a Kawasaki drill. he has charged the 2 batteries and neither of them works . he has had it for 1 1/2 years and never had trouble till a few days ago.we have been using it but didn't charge...
check voltage on batterys with volt meter if the batterys are weak try recharging. try them in flashlight or other peice of equipment.. try moving forward reverse switch while pressing trigger and maybe clean battery contacts with eraser.
Jan 15, 2011 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Rear end will not free wheel and reverse not moving very fast.
you did not say what kind of mower but mine has a rod sticking out of the back that you pull out to allow it to freewheel
Jan 24, 2018 | Craftsman Garden
Camera power not working
It is proberbaly because the batterys are out because batterys dont last for ever even rechargable batterys only last for 2-3 years it is best to buy a new camera if it is not the batterys causing the trouble and by the way if you are buying a new camera buy a sony the repairs personnel can easily sort any probs when you get any
Apr 24, 2009 | Canon Cameras
I AM ONLY GETTING 9.3 VOLT TO THE MOTOR
Just to be sure have the batteries tested with a load tester. Then ohm test the brake. It should be around 35 ohms.
Dec 21, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
106 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
