Question about ViewSonic VX924 19" LCD Monitor
There is no sound. I have two cables attached - a power cable and one other, but I not there is another female many pronged plug on the back of the set.
  • 4,924 Answers
The sound for this will be in the audio in ...and on a 3.5 jack ....you will have to get the signal from the green out of the computer and insert it in the audio in ..and will work ..remember a normal 3.5 jack ..
Posted on May 30, 2010
Bernina artista 165 has always worked perfectly. Ran last night. I turned it off. When I tryed to turn it on today there was no power - checked all cords and outlets. After looking it over for 30 min. I...
Congrats on your upcoming marriage
If the attachment to the machine is 2 prongs (male) and the cord has two small holes for the prongs (female) you can try gently squeezing the plug with the female end to make the contacts a bit tighter. It sounds like the connection is not making contact properly
May 18, 2017 | Sewing Machines
I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    I have a superlu pra-h7a. I also have a cable that connects to the bottom via a three pronged male plug with with a female connector on the other end. i have not used this in years, and can't remember how...
    You need to connect it to a mixer first and from there to an amp/speaker combo. This microphone needs phantom power and you can only get it via the mixer. Also, you can control the volume via the mixer. Depends on what kind of speaker you have (active or passive) you will need an amplifier. If you're trying to plug it into a guitar amp, it won't work without a mixer. Plug the 3-prong xlr male cable into the input of the mixer. The 3-prong female xlr end goes into the mic.
    Oct 08, 2010 | Superlux PRA-H7A Professional Microphone
    Power Cable Replacement
    Try ebay. If unsuccessful you may have to convert the plug on your set to a standard one that will work with a normal standard wire.
    Jul 28, 2017 | iLO V27DMBX Television
    Need help to hook up IBM color flatbed scanner
    Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
    If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
    IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
    Plug in power cord and then power up PC.
    Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
    Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
    Dont know how to turn on
    The monitor has and adapter type power cord that plugs into the computer end of the VGA cable. Look for a small round hole at the PC end of the cable.
    Jun 08, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
    Hannspree tv
    This is a very difficult question to answer without knowing more info, but here goes:
    Check the power cable, there should be only place to plug it into. This may be one of several styles depending on your model, usually a 3 prong female (just like your PC's power cable) connector, or a single pin female connector (looks male but has a hole in the center) will connect to the back of the monitor.
    If you get power, but no image: VGA connections will use a large blue connector with 15 round pins, 3 rows of 5. DVI will be a large white connector with slotted pins, with varying amounts of pins depending on the type of cable (analog, digital, or both). HDMI will be a small connector that resembles a large USB connector. You may also be using a composite or component cable, which will be color coded to the ports on the monitor.
    All styles of connectors will physically only connect to the corresponding port. Check all connections and make sure they are all secure and connected to the correct locations on the monitor. Doing this should resolve your issue.
    May 12, 2008 | Hannspree HW191D LCD Monitor
    Jazz dv179
    The Charger has a standard two pronged plug to go into the wall. The other end goes into the camera at the back bottom. You will see the female received for the male plug.
    Dec 18, 2007 | Jazz DV-179 Digital Camera
    ViewSonic VX924 19" LCD Monitor Logo
    Top ViewSonic Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
