I came across a refurbished EIZO FC 2090 3MP monitor. I would like to use it, but I cannot use it with my current video card. Are there any drivers, or a specific video card that I need to use. Thanks
  • 8,404 Answers
Before you invest much more time in this project, check the Windows Compatability List to see if the monitor is supported ... find it here ... http://www.microsoft.com/whdc/hcl/default.mspx
Posted on May 30, 2010
How to reset eizo monitor
resetting Eizo monitors - RetouchPRO
www.retouchpro.com > RetouchPRO > Tools > Hardware
Apr 10, 2008 - 6 posts - ‎4 authors
is it possible to rest a CG241W to the default factory settings?..the consultant that is working with us is having trouble getting a decent ...
Eizo
www.eizo.se/default.aspx?page=21
EizoOften there are no faulty sub-pixel on a EIZO LCD monitor, but according to the EIZO... Reset the monitor to the factory default settings by choosing 'Reset* in the ...
Setting Eizo Logo Display On/off; Resuming The Default ...
www.manualslib.com > ... > Monitor > FlexScan S2202W > User manual
The EIZO logo appears on the display when turning on the monitor. This ... default settings, and the other is to reset all the settings to the default settings. ?.
Jan 23, 2016 | Eizo Computers & Internet
Pixelated appearance
Hello Anon, it seems you may be looking at a driver conflict here. Setting up this project is easy; bring in a second monitor and prepare to swap between the two frequently.
1. On the Eizo's menu initiate the self calibration.
2. When the Eizo completes the self calibration and the Pixelation persists, uninstall all the Graphic Card drivers on your computer.
3. Install the manufacturer's specific graphics card drivers from the manufacturers website.
4. If the monitor continues to be pixelated then ensure that your GC is 4k ready. (That it can natively display 2560x1440 @ 16:9 aspect ratio).
I suspect your Graphics Card is not up to par, it likely has full 1080 but not enough to push 4k as your monitor natively runs. Purchase any GC with a 4k ready capacity and you will enjoy the full beauty of your purchase.
Source:
http://www.tomshardware.com/forum/304706-33-completely-uninstall-graphics-drivers-install-ones
http://en.wikipedia.org/wiki/Graphics_display_resolution
http://www.eizo.se/default.aspx?page=11&product=CG277-BK
Mar 06, 2015 | Eizo Nanao Eizo - CG277-BK 27"" Wide...
S1921
Here is the link to Eizo's driver page.
This issue may not be the monitor but your video card. If the card will not support the driver you can't force it to use it.
Dec 06, 2013 | Eizo FlexScan S1921 Monitor
Eizo foris fx2431 osd problem
If you downloaded and installed any software with this monitor, uninstall it, see if the issue goes away then reinstall it.
The other thing to look at is if you are using any adapters in conjunction with your video cable.
Dec 03, 2013 | Eizo FORIS FX2431 Widescreen LCD Monitor ...
The screen on my Eizo CG241W monitor has begun to display a bright pink background intermittedly. Occasionally the screen displays solid green.
Did you verify that the video cabel is seated properly and no bent pins?
You should also try it with another PC to make sure i is not the PC's video card problem.
Please post back what you find.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 07, 2011 | Eizo CG245W 24 inch LCD Monitor
My friend has moved her computer to my place and once the the Eizo CG211 monitor was plugged in, it is not working. It was fine at her house. I have the same monitor and switched power leads, these work...
Does her computer work with another monitor? We need to find out if it is the monitor or the PC problem first. Your monitor works OK with her PC?
If it is the monitor, you may have to look for loose connection or the components may have failed.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 28, 2011 | Eizo ColorEdge CG211 21.3" LCD Monitor...
I have a custom built computer with dual NVIDIA GeForce 8400 GS - 512MB - 16X PCI Express. Until recently, I had two Eizo L565 monitors. I had one connected by DVI-D and the other by D-Sub. I acquired a...
You have to use the dvi-d cables on both video card in order to get the higher resolutions on both screens. also the nvidia control panel must be set up the right way so that both screens receive the higher resolution.. there should be a selection for panning across both screens, and another for selecting apps on 1 screen and main os on the other. try changing those settings around, more than likely that is the reason that it's going at a lower resolution.
Dec 17, 2010 | Computers & Internet
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
Desktop larger than screen
Is AGP enabled in the BIOS?
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
