Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
THe Washer is shutting down before wash cycle complete
THe Washer is shutting down before the cycle is complete. Usually towards the end of the wash cycle, before the rinse starts.
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER, you need to check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on May 30, 2010
Reset frigidaire affinity washer
Yes there is buy a new drain pump so all the water will get out
Jan 19, 2014 | Washing Machines
Cycle switch keeps tripping
Switch actuator (usually on washer lid) is probably broken if you can complete the cycle by depressing switch manually.
Jan 17, 2012 | Amana 3.2 cu. ft. Top-Load Washer
Washes until end of wash cycle and stops working before the rinse cycle. Same on all settings.
replace lid switch
where yout timer asymbley and controls are a screw in the bottom left and right corner remove and flip timer assymbley back towards wall in dead center of cabinet there is a quick disconnet for the cord disconnect the complete following steps..
there should be another quick disconect usually sitting horisontal that usual for your lid switch remove and jump across the two outside wires reconnect power and put washer on drain and spin if it starts to spin this means the switch connected to this connector is bad called a lid switch which controls the washer not to spin if the washer lid was left open this is a safety mechanism and must be replace with a new switch i donnot reccomend leaving this switch jumped out even though you could do laundry untill your part comes in.....
Jan 24, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
My washing machine does not complete full cycle it washes and then shuts down at rinse cycle. When advanced over first issue it will complete the cycle.
Your problem is going to get worse, really soon. The DC motor on the bottom of the washer needs to be replaced. The windings inside the motor have shorted together and cause it to draw too much power, shutting down the washer. The motor is expensive, home warranty covered mine.
Oct 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
GE washer won't complete cycle
there are contacts inside timer which may not be working properly. in any case they are not repairable.
Oct 28, 2009 | GE Washing Machines
Kenmore 20692 top load washer won't spin. The
This is most likely a motor coupling. Pull washer towards you about two feet tilt back, look at floor for black sute. The coupling is attached to the motor to the transmission. It cost about 15.00 and takes a novice less than an hour. There are two 1/4 inch srews, one on top one on bottom , remove these use a scwrew driver to pop off the clips,pry off coupling on both side and replace.
Mar 12, 2009 | Washing Machines
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
241 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
