Question about Technics SL-MC700 110-Disc CD Changer
Error code F-26 - Technics SL-MC700 110-Disc CD Changer
The servo LSI has malfunctioned.. but I don't know what that means, and where I can get it fixed.... do you??
Posted on Aug 15, 2010
What is the f-26 error code kenmore he2 dryer
motor/drive failure. a trained technician should perform a diagnostics check to determine if it is a electronic or motor malfunction.
Aug 13, 2014 | Kenmore Dryers
What is an F3 26 error?
Appliance tech has a computer program or hand held device that has the answer. Newer machines are built to that spec. F3 shows where the main component of the error exists. #26 may not be a commonly occurring error. Go to Google and type in F3-26 or something similar. See what happens. Failing that contact a repair Company or your trusted Tech.
Jun 28, 2014 | Samsung WF337AA Front Load Washer
What does obd 1 code 25 and 26 mean?
EOBD II Error Code: 25
Description:
System too Lean, Bank 1
Possible Causes:
- Intake/exhaust leak.
- Secondary air injection (AIR) system.
- Manifold absolute pressure (MAP) sensor.
- Mass air flow (MAF) sensor.
- Fuel pressure/pump.
- Injector(s).
- Evaporation emission (EVAP) canister purge valve.
- Heated oxygen sensor (HO2S).
- Contaminated fuel.
EOBD II Error Code: 26
Fault Location:
System too Rich, Bank 1
Description:
- Evaporation emission (EVAP) canister purge valve .
- Fuel pressure.
- Injector(s).
Hope that works.
May 24, 2014 | 1995 Toyota 4Runner
Vaio vgn c13g b
Hi there, copy the error code and google for solution.
Solution Steps:
The device is configured. (Code 26)
Restart the computer to complete the installation.
Solution button: Restart Computer
This code means that a device was not loaded. There may be a problem with the device driver or does not have all the drivers installed.
To resolve this error, follow the recommended solution. If this does not work, use the Device Manager to remove the device and then run the Add New Hardware Wizard in the Control Panel. If the error code persists, contact the hardware manufacturer or consult the Microsoft Software Library to obtain an updated driver.
Best Regards
Dec 18, 2013 | Sony Computers & Internet
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Precor Treadmill 9.21si Error Code 26, what does it mean
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
F-26 error message
F-26, is a door lock switch error code. Some things to try; Unplug the washer for 1 minute and see if the error clears. If not, try entering the diag mode by pressing any key except pause/ cancel. Press for 4 seconds and release for 4 seconds 4 times. If entered correctly, all lights should light and the first error should appear. Press the same key to advance through all the errors. When the errors finish. It will start an automatic test mode that tests all componets. The first thing it will test is the door lock. If this fails you more than likley have a door switch problem. Let me know how you make out. Catriver
Mar 06, 2009 | Kenmore HE2 Plus Front Load Washer
Motherboard beeping
Error code 26 could mean faulty or not properly seated RAM or video card. Can also mean keyboard error. Error 5D is an audio problem. Hope this helps.
Feb 08, 2009 | Lexmark T430 BAR CODE CARD (26H0395)...
Open Questions:
See all Technics SL-MC700 110-Disc CD Changer Questions
Technics SL-MC700 110-Disc CD Changer Logo
261 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
