Question about Mitsubishi MSZ-A24NA Split System Air Conditioner
Does not blow cold or hot air
Everything seems to woirk fine it just does not blow cold or hot air
    Sniper:
  • 81 Answers
Haved you cleaned the filter?? Clean them! It might be out of refrigerant. Have the unit professionally checked.
I take the time to help, so please rate me!
Posted on Jun 27, 2010
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
Heater blows only cold air. in and out hose are both hot, what could it be.
The door that mixes hot and cold air seems stuck in the cold air position. Check for a vacuum hose leak.
Feb 27, 2015 | 1994 Lincoln Town Car
I have a 2003 alero with the v-6 what happened was driving down the road the heater works fine. then all of a sudden it was blowing cold air and the temp gauge started climbing. it started blowing how air...
Sounds like the water pump is cavitating . Replace water pump. Check coolant level also. Open the bleeder valve usually located on thermostat housing to remove air from system. close valve when coolant is present while filling. close radiator cap and top off recovery bottle to correct level. These engines are prone to overheating, do not let temp gauge get in the red.
May 01, 2017 | 2003 Oldsmobile Alero
A/C fan blows enough air but temperature is niether hot or cold
CHECK YOUR PRESSURE SWITCH. IT IS ON YOUR EVAPORATOR.
Aug 04, 2009 | 1999 Cadillac DeVille
Center vents cold side vents hot please help bthibs
hello,good day,seems your recirculating pump need tobe check,ty
May 15, 2009 | 1996 Mercedes-Benz C-Class
A/c blows cold parked then blows hot after a few miles
engine fan not kicking in at right interval to bring air in so its pulling in hot air threw ducts
or you have a disconnected duct blowing all air out not to right place
guages could be faulty or bad a/c relay
Jun 10, 2008 | 1993 Lincoln Town Car
Mitsubishi MSZ-A24NA Split System Air Conditioner Logo
359 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
