Question about LG LRSC26925 Side by Side Refrigerator
Lg fridge lrsc 26925tt inop fridge lights-inop display , freezer light works. Unplug for 5 min, plug back in still no power to entire appliance except the freezer lights. Any ideas?
  • 120 Answers
Repl the mother board and check for error display to see what cause it to turn off in the first time
Posted on May 30, 2010
GWB227wlqa. Why is the panel on the front beeping?
If you haven't yet... unplug it for 15 mins without opening the doors.. check the plugs on the bottom that run into the door panels unplug and plug them back in again. Making sure they are clean and fully pushed together.
Aug 06, 2015 | LG Refrigerators
I have a LG LRSC26923TT (2005) model. The entire fridge shuts down. The LCD goes blank and only the freezer light is on. Unplug the machine plug it back in and it fires up again. When the compressor kicks...
Were you able to figure out the problem or solution? i'm experiencing the same issue as of last night on the same exact refrigerator. Hope so!
Nov 02, 2010 | LG Refrigerators
Not cooling fridge or freezer.
need cooling at the back, unplug for about 15 mins, move it for about 1 foot from the wall then plug back.
Sep 15, 2009 | Refrigerators
Describe your LG LRSC-26922 Side by Went to get ice this morning and noticed that the front panel was not lit. The lights go on inside but, there is no sound and the ice in the freezer is solid. When we...
PCB control fault. Don't keep perishables more than 6 hours. If the date on it is "best before" don't worry too much; if it's "use by" keep it refrigerated or use it today, even if you have to cook it and refrigerate it when fridge repaired.
May 03, 2017 | LG LRSC-26922 Side by Side Refrigerator
Lg not working
Please always post an exact model number. That info helps us so we can give much more specific help, including looking up any service bulletins or parts. Regardless of the configuration of freezer location to fresh foods compartment, as a general rule when the compressor is running the evaporator fan (in freezer) and the condenser fan (near compressor) should also be running. If all OK, look for frost build up on freezer wall (usually the back wall) indicating a defrost problem (most often a defrost heater failure, but can be an electronic control board or other component) Check that the door gaskets are sealing. Is there an ice maker? Do an "ask me" or look for me for an on line chat with more details if you have further questions.
Aug 29, 2008 | LG Refrigerators
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Samsung american style fridge freezer power loss after internal light blew
try to unplug for 2 min and plug back in to reset the unit otherwise sounds like you cooked a board
May 20, 2008 | Refrigerators
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Jan 02, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
LG LRSC26925 Side by Side Refrigerator Logo
141 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
