Getting the message "no input detected from your microphone" when trying to use yahoo voice
  • 4,924 Answers
OK ..there are more than one scenarios here ..
First thing to check is the mike itself..tobe plugged well into the pink in ..and if it is a internal one I guess its ok ..
after that click on the icon shaped like a speaker in the tray system on the tsak bar (right click ) and open the volume control..if the microphone is not in the list ..click options in the left ..and properties...It will be displayed a list of devices..and you should choose from the list the mic..and check the square ...This will place it visible and activate it ...Check again the volume to be up ..for the mic..and not to be muted..
In this moment the mic is active and ok ...all that should be done its to see if it is picked up by the Yahoo...so ...open a conversation window with someone ..than in the action button ..choose call set-up ..it will show a window that has to be clicked next to make the call setup...first when you get to the mic setup...you have to make noise and do not move on until the level is moving and its says mic setup successful ...if it do not appears to detect the mic...see the device list in the window and choose the device you use...if themic is incorporated into the camera and it is a usb camera ..choose that from the device list ..after that make noise to be detected..and move on if it works .when you finish the setup with success it will work and you already can make calls
If teh other has issues in hearing you ..you can always go to the volume control center (like the first time ) ..and choose advanced under the options ..and after that in advanced under the mic line ...click to boost it up..and will double the fidelity ..
Have a nice day and please rate me ..1
Posted on May 30, 2010
How do i troubleshoot microphone on a acer aspire one d150
have you tested the microphone with another application like windows sound recorder? if not i recommend you try that and verify the microphone is functioning. if it is then go into yahoo chat and check your options and verify you have the correct sound device selected for voice input.
Feb 26, 2012 | Acer Aspire One D150-1587 Netbook
A4tech PK-7MA flexicam, the cam is working but yahoo messenger cannot detect the microphone cant able to make voice call
Go under the volume control in Windows and make sure that Windows is using the camera as the recording/input device and make sure the volume isn't set too low or muted.
Apr 27, 2011 | A4tech PK-7ma Flexi Webcam
"no input from your microphon
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Feb 11, 2011 | Computers & Internet
Yahoo voice call not working
Make sure ur mic settings are configured properly.
Open Yahoo Messenger Window, goto Actions > Call Setup as seen below:
Now follow the step by step instructions, and select the input and output source from the drop down menu on the setup screen until the microphone and speakers are working properly with this wizard.
Yahoo Audio Prefernces
Go to yahoo messenger main window , Messenger > Preferences > Calling & Audio
In this setup, select the microphone input from the dropdown, and similarly the speaker settings.
After selecting the proper input and output, the voice char worked just fine with me. Hope it helps you solve your problem.
Aug 26, 2010 | Yahoo Messenger
I have downloaded ym version 8.1 but the call icon is not showing and i cannot make a call pc to pc.what to do.
thus the computer you using has a microphone? a built-in microphone socket? if there is, then you have activate it. just go to control panel.
Jul 02, 2010 | Yahoo Messenger
Realteck mic problem
Well, if it's working when you record sound, then there might be settings related problem with the skype or yahoo messenger etc... Let's get started with the "skype" open your skype - sign in - click on "tools" select "options", on the left pane of the options windows, click "audio settings" and now on the right pane, check the "microphone" settings and verify it's set to "Realtek High Definition Audio", if it's not, do so now. click "Save". You can set the volume manually by uncheking the "automatically adjust microphone settings" and turn up the volume slider. Do the same with the yahoo messenger, but you can't set this before you log in. In yahoo messenger you need to go to the "preferences" - "Video and Voice" from the "Messenger" menu. Also make sure, that "digital input or output" isn't selected.
Good luck. Thanks for using FixYa.
Jun 06, 2010 | MSI K9N6SGM-V Motherboard
I have connected the samson mic to my computer. input not detecte
A condenser mic. requires "phantom power" usually supplied by a mixing desk. Without this, there will be no output signal from the mic.
Jan 12, 2010 | Samson C01U - USB Studio Condenser...
Yahoo Messenger 9.0 PC to Phone call results in No Voice Detected
Not a permanent solution. Rebooted the computer and I was able to connect. Tried calling again later and same problem occurred (No voice detected). Re-booted again and it cleared up. Haven't tried calling again yet. Never had this problem with messenger 8.
Mar 19, 2009 | Yahoo Messenger
Yahoo messsenger voice chat problem
yahoo search engine brings up something different than what I put into search
Jan 13, 2009 | Yahoo Messenger
Yahoo Messenger Troubleshooting
voice fix for yahoo and yahoo clients
Sep 15, 2008 | Yahoo Messenger
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
