Question about KitchenAid KEYS700LQ Electric Dryer
KEYE778BALO I NEED A HEATING ELEMENT.NEED MANUAL TO FIX IT
  • 1,344 Answers
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
Posted on Jun 05, 2012
I need top heating element
to be honest cost more usually to fix than buy a new one but your local appliance repair shop is best bet
Jan 17, 2015 | GE Ovens
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
Ler4634pq1
It could be: the knob/control panel, one or more fuses, or the heating element.
When this happened to me it was the heating element on my electric dryer. The heating element stopped working because the air flow was blocked, causing the heating element to work too hard and develop a break. The air flow was blocked because you're supposed to take the dryer out every 6 months and clean the lint out of the vent behind the machine. No where in any owners manual does it really explain this. For my machine, the heating element was about 50 bucks and it was easy to fix it myself, but don't order a new heating element unless you know that's what it is. It could also be a problem with the knob, one of the fuses, etc. The heating element is the most expensive problem. The fuses are cheaper. If you have a multimeter you can check the resistance, but the place where I buy my appliance parts will check them for free. You might try calling around to see if a place near you will do that for you.
Nov 04, 2013 | Whirlpool LER4634J Electric Dryer
Temperature sensore probelm
make this test and fix it. God bless you
Heater
This is the most common reason why your dishwasher is not drying. To check this remove the toe kick, remove one wire from heating element and check ohm reading. Compare the reading to the tech sheet or service manual. If it has no continuity at all replace the element. Make sure the element is getting power. To do this connect voltmeter to each lead of the heating element then select a dry cycle you should have 120 volts if not the problem is in the control. If it does have power and does not heat up replace the element. The heating element is easy to replace
Timer/ Control
This is not as common as the heater but can fail. To check this select a dry cycle and check to see if the heating element has power if it does not replace the control If the element does have power and does not heat up replace heating element.
Jul 24, 2013 | Dishwashers
Masterbuilt Smokehouse model 20070712 won't smoke wood chips at 225 degrees
I had this exact same problem with my Masterbuilt Smokehouse even when brand new. I notice there is some variability in the space between the top surface of the heating element and the bottom surface of the wood chip box. I measured about 1/4 inch between the two surfaces when the heating element was seated bottomed out and touching the wire grill below it. What I did to fix the problem was to gently (make sure everything is completely cold before doing this) lift up the end of the heating element farthest away from where it enters the enclosure just a little bit so that when you put the woodchip box in where it is supposed to go, the top surface of the heating element will now be in contact with the bottom surface of the woodchip box. This arrangement allows much greater heat to heat the wood chips during the part of the heating cycle when the heating element is on (naturally the heating element cycles on and off to regulate whatever temperature your are targeting for your food being cooked). Now, because of this contact, every time the heating element comes on, enough heat will enter the woodchip box to keep the chips ignited. My next step is I am going to put a small 1/4 inch thick piece of metal beneath the heating element and the rack that is under it to force the heating element to stay sitting 1/4 inch higher so that it is always in contact with the lower surface of the woodchip box. Making these improvements allowed me to continuously get smoke when the big smoke box was at 225 degrees F.
Without making this fix, the unit would stop producing smoke at 225. Hope this makes sense and helps you.
Aug 25, 2012 | Masterbuilt 20070106 Electric Smoker
How do you fix the heating element in an amana front loading dryer?
are u sure its the heating element? there are several other parts that are much chaper that typicaly go out and cause the heating element to go out
you have a bad t-stat or a bad heating element most likley a bad t-stat
if you need help fixing check this out
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270664800939&ssPageName=STRK:MESELX:IT
Nov 16, 2010 | Amana Dryers
Bosch SHU 3032 heating element out. How do I fix this? Is it hard and is there instructions on how to do it?
Hello sassydeel, changing the heating element is quite a job, but are you certain you need one ? I ask because I have serviced Bosch built dishwashers for alomst 20 years and I have never seen an element faulty, that's not to say I haven't seen heating issues or it doesn't happen...I'm just saying how rare it is, so make sure it is faulty. Have you confirmed it with a meter ? Let me know, and if you'd like to provide an email address I can send you a complete repair manual via "pdf" through email. Macmarkus :)
May 06, 2010 | Bosch Dishwashers
Heating element is getting red hot - like a heater.
No the first thing I would check is the vent going outside may be cloged the air going across the heating element should keep it from glowing real bright
Mar 30, 2009 | Maytag PYE2300AY Electric Dryer
HEATING ELEMENT
hi follow the manual: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8574093.pdf if it dosent work then as you mentioned the heating unit is bad you can replace it by yourself by buying it and insalling it its easy as installing a lamp but you can call for help (number in the manual) good luck
Mar 21, 2006 | KitchenAid 24 in. KUDI01IL - Multiple...
KitchenAid KEYS700LQ Electric Dryer Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
