I need driver for xp, usb converted por to serial.
  • 47 Answers
Which model and make?
Posted on Apr 08, 2008
My windows xp computer gives me a message that WASP USB to Serial converter is not compatable. It suggested I try to find a device driver that is compatable with win xp. Please Help. Thanks. Paul
there's a problem with the OS in the registry, the unit itself doesn't need a driver, the OS supports it directly.
OS = Windows Operating System.
Try the unit on a different system. If it works, look to your system registry
if it doesn't , the unit may be defective (most likely is)
Mar 21, 2011 | Wasp USB to Serial Converter...
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
I am trying to install the Singer professional Sew-Ware software on my new computer that us running Windows 7, I had to purchase a Serial to USB cord which I attached and installed the cord. When running...
Singer.com's FAQs provide the following:
Sep 22, 2010 | Singer Professional Sew Ware Options 2.0...
Can you convert a serial ArtPad II to USB?
I bought usb to serial cable from ebay with driver software for less cost and then download driver from Wacom for Artpad II (KT series). My laptop is Window XP. Had both drivers installed and it works. I can start my homework with it. Really, I just use it.
Apr 01, 2009 | Computers & Internet
Web cam
necesitaría el cd de instalacióm de camara web modelo e-messenger 112 enviar por favor a belencita_32@hotmail.es
Jul 28, 2008 | Genius Computers & Internet
F5u109 Serial USB PDA Adapter.. Need Drivers for XP
calling you no. I am a belkin partner. are you needing drivers for the usb device
Feb 11, 2008 | Belkin USB PDA Adapter [ F5U109 ] (109198)...
Problem with BF-810 usb to serial
windows xp can not install a driver for bf-810 adapter.
Dec 17, 2006 | BafoTech BAFO BF-810 Serial Adapter
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
