Question about Nintendo Wii Console
System won't read disc
Tried cleaning disc, & unplugged it as per manual! is there anything that cleans laser?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
I have fixed lots of them but %1 fixed by cleaning the lens , you may need to send it for a repair :( Thanks
Posted on May 30, 2010
Disc in system but it is reading no disc?"???
I suggest to try with another disc. If that happens again, then try to clean lens with special disc. And if then won't help, then you'll need to change laser that reads discs. Usually it's not worth trying
Aug 30, 2011 | Insignia NS-8PDVD
Hardly used it & now it doesnt recognize any dvd any clue what could be wrong
Laser eye reading buble,might be dirty,reqiure cleaning or having problems with those DVDs disc's itself like dirts,grimes or cracks and big scratches on those DVDs disc's laser shinning surfacing data's reading side?Check all ur DVDs disc's again u are using,might just require a good cleaning on DVD's discs on the reading data's shinning surface sides,with some dish washing soap?If the DVDs disc's are not the problems.Tries websites like Ebay.com,Amazon.com to buy a DVD disc cleaning kit.By using the DVD cleaning disc,might work,might not.But than u don't have to be littery taking the portable DVD player aparts and used some Q tips,dipping in with some rubbing alchahol to clean the Laser eye reading buble itself.
Dec 01, 2010 | TruTech PVS12701 Portable DVD Player
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
The disk isn't spinning. When tray closes, it tries to spin for a moment, but then it doesn'tt.
When you first put a CD/DVD into the Playstation 2, the disc spins enough so that the laser can read if it's a CD, DVD movie, DVD ps2 game or CD ps1 or 2 game to spin at the appropriate speed. If there is no disc inside, or the laser thinks there is no disc inside, the disc will only spin that 1/2 of a turn. So what would cause the laser to think there is no disc inside?
A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable. I would suggest using a 400C since it is a better laser [and more available] than the 400B. YES, despite anything you have read, you CAN replace a 400B with a 400C IN ALL CASES.
Jun 05, 2009 | Sony PlayStation 2 (PS2) Console
Bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Nov 27, 2008 | Bose 3 2 1 GSX System
Will not initialize a new disk; often freezes up when trying.
Hello, I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. Also, are you using the same type of discs, Some discs are better quality than others try using Imation they read in almost anything. Also if you do have to clean the lens you may want to lighty lubricate the rails the laser moves on using a drop or two of 3in1 oil per rail.
If it still will not work then I would say that the laser pickup is failling. Specificly the laser used for burning the disc, Since there are usually two lasers one for burning & one for playback.
Jun 04, 2007 | Samsung DVD-R135
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
Nintendo Wii Console Logo
102 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
