Phillips 18 year old televison
Phillips television. the television has a 2cm silver line going right across the television. no picture but full sound. does anyone know what the problem is and is it worth fixing?
regards Kathy
    Brigadier General:
  • 6,966 Answers
Hi Kathy,
If you are referring to a single bright line left to right, then I would suspect that your TV have a vertical output failure. Depending on the particular model, this could be a single IC or a transistor pair. This is relatively an easy job and component replacement should be readily available. Since the unit will be opened for confirmatory diagnosis and eventually parts replacement, may I also suggest that you ask the service personnel who's going to do the job to likewise replace the vertical capacitor. They have a tendency to dry out after some time. It is the biggest of the lot (of capacitors in the vertical section). Parts cost would also be relatively low.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 08, 2008
SOURCE:
Phillips rc122 roku
Phillips Rc122 code for lg Roku tv on spectrum/timewarner is 1098, it's listed under some other tv's but I have full expanded capabilities took me a year to figure out, so had to share.
Apr 26, 2014 | Roku Enhanced Remote for 3
Our lcd phillips tv screen turns completely white after about an hour of use
The TV, most probably, the display circuit or the display itself has developed dry solder/components leaking and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Philips Televison & Video
Phillips 42" LCD Mod#42PF722OA/37 picture is off
hi have you googled it or how to fix and put your problem then youtube should find video some where on there to help hope this helps good luck
Mar 04, 2018 | Philips 42PF9996 42 in. HD-Ready LCD...
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
I have a Phillips LCD tv just coming up to 2 years old. I now have a black line across the screen about 3" from top of screen. What is this and can I get rid of it??
You probably have a bad plasma panel. Have a repair shop check it out though because it could also be one of the buffer boards.
Oct 14, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
I currently have a phillips 28pw9308, its just 3 years old, but i have a green screen with green lines across it, i hear the programmes clearly but no picture can u help please?
sounds like you have a shorted green gun in the CRT. It may also be the green drive transistor. Check the trans first, and if the trans is good you will need a new CRT
Mar 10, 2008 | Televison & Video
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Ekse
