Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Can not get tractor started
Hey, I took out all of the safety switches on my tractor ( a19.0 poular ) and I though that I had wire it back where it made a curent to the igention switch. I have tryed to connect the wires several ways and I get nothing. also I had it started befor I took the wireing off but it spit and spudder and died. any help would be helpful. Thanks to every one who reads this. Steve
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
If you have only 1 small wire on the solenoid then it is the exciter wire. What is suppose to happen is when you turn the key to the start position the exciter wire recieves 12 volts from the key switch which activates the solenoid plunger which in turn connects the battery cable side of the solenoid to the starter side and then the starter turns. Most of the time it is a safety switch preventing the 12 volts from reaching the solenoid exciter wire.
If you have 2 small wires on the solenoid then the other wire is the ground for the solenoid. You can easily verify this with an OHM meter.
You can also check the safety switchs. Sometimes just unplugging and reconnecting the safety switches will clean the contacts and fix the problem. You should have a clutch/transmission, blade engage and seat safety switch. You may have a couple of more depending on the age of the tractor.
The safety switch in a lawn tractor allows the tractor to shut off if the switch is released. It is composed of a spring component that will deactivate the engine when not set properly. This safety switch is necessary for the lawn tractor to run, and move forward or backwards. The transmission and engine both are wired into the seat safety switch, making it necessary that it be enacted for the tractor to run..
For the safety switch to function properly, it is placed under the seat of the tractor. When the rider is sitting down in the seat, the weight compresses the spring to activate the safety switch, which allows the engine to start and remain running. For some riders this may be difficult and the need for extra weight or an adjustment in the sitting position is necessary to force enough weight onto the spring to keep it compressed. For smaller riders, this can prove difficult. For those with difficulty keeping the tractor running, due to a lack of weight on the switch, a block can be added to the back of the seat to increase the weight pressing on the switch. Other methods are also possible, such as tying a rope to the seat, placing pressure on the switch. This will eliminate the issue, but also raises safety concerns as the tractor will not shut off once the rider dismounts.
When the spring is decompressed and a rider is no longer placing weight on the seat of the tractor, the spring will open back up, initiating the kill of the engine and transmission. This switch is necessary to eliminate lawn tractor accidents where riders fall off, or leave a tractor running unattended. Once the rider leaves the seat, the engine will stall out. This is made possible by the wiring. The switch is hot wired to the engine. The spring, when compressed, makes the connection between wires possible, thus allowing the engine to run.
Thank You
If you donot have further queiries please donot forget to accept the solution.
Posted on May 30, 2010
Ford 1700 tractor. Wont start unless clutch is depressed.
Hey Ray,
I would think this is normal... its a safety feature..
Sep 25, 2017 | Ford Garden
Battery ok, but nothing when I turn the key. Does this model have a fuse under the seat
ALL JD Tractors have a seat switch. But you have several other safety switches as well. Neutral safety switch, Mower clutch off switch. Pedal Switch. On the back of the key switch there are several wires. you should see two yellow wires. Put a jumper across these two wires and try again to start it. If that solves your problem one of your safety switches is bad. But I would start with the seat switch. Unplug it and install a jumper across the wires going to the frame. Then try to start it. 9-10 times its that switch that goes bad.
Apr 17, 2016 | John Deere Riding Lawn Mower. D170 54 in....
Why does engine cut back, even though the mower still cuts well?
Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
Disable all lawnmower safety switches
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
How to test lawn mower solenoid
6th How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 16, 2016 | Garden
The safety switch in the t1400 seat does not stop the engine when I get off. Can you tell me the connection to the engine as the seat switch has checked out ok
The safety switches are designed to work by interrupting the connection in the switch when you get off the tractor.. Sometimes the switch sticks or defective..try removing the wires from the switch and temperarly connect them together..start it if it runs then take the wires apart..the engine should shut down as intended if the switch was working ..now put the wires back on thebswitch and try to start if it does you need to replace the switch...good luck..
Feb 17, 2015 | Garden
Kawasaki FR541V withy no ignition?
Did it start when you got it back from them? I would start by checking all the safety switches. See if the wires pulled off the switches
Oct 18, 2014 | Garden
Garden Trctor Model 917.273023 . Key switch broke, wore out. replaced it. started up great, tried to mow and the electric clutch would not engage, checked out wireing restarted engine. and engaged...
Bill, not sure, but, the engine will not crank with the clutch engaged, I don't know what happened, but sounds like the clutch switch went out and took the mower with it. Take the wires apart between the ignition and the clutch and hot wire them to see if the clutch jumps. If it is working, then make sure it is off, or disconnected and try to start it, then take it from there, if it starts, you know it is the switch. If it doesn't start, then you can go look at other safety switches. make sure it is neutral, mower off, driver in seat, clutch in, etc, Hope this helps.
Jun 29, 2011 | Craftsman Garden
I have a sears lawn tractor with a Kholer courage 20 HP. Engine just clicks with the key is turned. Took the battery to have tested and was told the battery is good. But, the tractor will start if I jump...
No, it sounds to me like it is one of the safety switches is a bit corroded, along with a battery that may not be fully charged, you are not getting enough voltage to turn the engine over. What I would first do it disconnect the battery, take apart all connections of the cables, where it mounts to solenoid, where ground cable connects to the tractor, etc. Then put everything back on. Charge the battery, or jump the tractor to get it started and let it run a bit, which will charge the battery. You may need to check wire connections that go to various safety switches, too. Under the seat, where it connects to the transmission, etc. This does not sound like a big problem at all.
Mar 08, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My john deere 214 won't start
The deck lift lever normally wont start lifting until you pull back at least half way.Ther are 2 sets of wires that go under the fender deck,one set goes to the seat switch and the other set goes to the neutral start switch next to the shift lever,just in front of the seat.The neutral start switch wires more than likley came loose when you pulled fender deck off.The micro switch is on the back side of plate that surrounds shift lever.
Sep 03, 2009 | John Deere &Reg Branded 27" Tractor Metal...
John Deere stx38....I can't get the engine to turn over. 1. Battery is almost new and test fine. 2.I took off the starter and tested it. (took it apart and cleaned it) it works 3. The key switch works...
Hi,,my name is Keith..and i feel that your starter is fine..and im almost certain its a bad safety switch..and to check a safety switch..you need an ohm meter..and you remove the 2 wires and ya put ya test leads in the switch..where the wires go..and you manually mash the switch button...and see if the ohm meter needle deflect...but i would start with the seat safety switch and work ya way to the others..i hope this has helped..if it didnt..please write me back
Jul 08, 2009 | Garden
Husqvarna rider 155 won't start
I took a wire and jumpered all of the switches until I found the one that would let the mower start. The switch was still good, but vibration or whatever had moved the plug just enough to lose contact. Plugged it on more firmlly - problelm solved. Thanks.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
