Question about GE DBSR453GB Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
GE DBSR453GB Gas Dryer doesn't dry clothes at all on the first cycle. On the second cycle they sometimes dry, and sometimes it takes three cycles, then they dry just fine. It's not a gradual drying, it seems like the dryer only heats up on some, but not all, dry cycles. Any ideas? Thanks.
  • GE Master
  • 43,501 Answers
Hi, If you have a gas dryerGE DBSR453GB Gas Dryer doesn't dry on 1st cycle. - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle. - 2_bing.gif rel='nofollow' href="http://www.fixya.com/support/t4726170-load_takes_more_one_cycle_dry#">dryer is electric2_bing.gifThere could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gifTroubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 30, 2010
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
DBSR453GB)WW gas ge dryer has a high pitch sqeek when dryer is running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | GE Dryers
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer takes many cycles to get clothes dry
While researching my problem I did find that the dryer vent hose could be partially clogged. The hose should be short and horizontal.
Mar 25, 2009 | GE DBSR453EBWW Electric Dryer
Dryer is not functioning (It doesn´t get clothes dry)
Usually the ignightor goes out in them. If you have a meter or way of measuring it, you can take off the front panel and it'll be on your bottom left side. You can disconnect it and you should see a short. here is a link to look at and it might help in the dissasembly prosess. By the way, when you 1st turn it on, you should hear a click within seconds down my that also. If it clicks it's very much so the ignightor. Pretty easy and cheap to do. Good luck
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=MDG7400AWQ&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY
Mar 14, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer cycle
HI thanks for your question. your problem might be the venting behind the dryer pull away from the wall to un kink the vent hose. thanks the appliance doc please rate my answer. thanks.
Oct 09, 2008 | GE DPSR610GGWT Dryer
GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Clothes are not drying
your blower motor is probably not working. enter the troubleshooting mode by pressing and holding my cycles and help at the same time for 3 seconds. this will tell you the problem. if blower is not getting up to speed you'll have to replace it.
Dec 03, 2007 | GE Profile Harmony DPGT750GC Gas Dryer
GE DBSR453GB Gas Dryer Logo
259 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
