Question about Fisher and Paykel GWL11 Top Load Washer
How do I get the Clean cycle
F & P toploader washer says I need to use the Clean Me cycle. How do I get the Clean cycle?
  • 159 Answers
You could just try doing a hot wash with no clothes in & some bi carbonate soda.just to flush the machine.If your problem relates to the water not pumping out then the pump is probably blocked & thats why its saying clean me.
Posted on May 30, 2010
GE washing machine Toploader will not fill with water
see this causes and remedies: God bless you
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control. see the diagram attached
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Jul 18, 2012 | Washing Machines
No hot water getting into Estate topload washer. Have to turn off cold tap completely to get hot washer for wash cycle. Then turn cold tap back on for rinse cycle.
One simple thing to try is to clean them screens on the water valve. Remove the hoses and get the screens out. Give em a clean or chunk em and wash on!
Oct 30, 2011 | Estate ETW4400VQ Top Load Washer
I have an toploader smart drive (about 12 years old now). I added some clothes to the machine last minute throught the cycle and now its just stopped. Dashboard lights come on but it wont drain or...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 21, 2011 | Fisher and Paykel WA37T26G Top Load Washer
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
My toploader washer smells sour inside
Remove the turning wheel in the drum and clean underneath and inside it. Also clean the filters. You can also descale the maschine by adding descaler and choose the hot washing cycle.
Jan 03, 2011 | Kenmore Washing Machines
Neptune tl washer
You will need to replace your timer control.
John
Sep 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes not fresh as with a topload washer
Call a servicing dealer and see if there is an update for your machine that has an extra circulation hose and port
Jul 04, 2009 | LG WM-2277HW Front Load Washer
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
White Clothes even with bleach and hot water don't get clean???
i have used everything to solve this exact problem!  I have to say the best detergent or bleach i have used in the lg..is the purex with bleach for colours it seems to work better than anything ive used...spent a fortune to have to soak my whites before putting them in this washer.  I must say im disappointed..
May 06, 2007 | LG WM1814CW Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
138 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
