Question about Apex Digital GT2011S 20" TV
The jack where you plug in the antenna got ripped out and I cannot afford to buy a new T.V. Where can I buy the part to install myself? THANK YOU SO MUCH!!!!!!!!!!!!!!!!
Antenna
if you can secure an exact replacement part/antenna, you can go ahead and study the actual setup of previous antenna and start tearing it down from the inside , or go to dealer to have it replaced at a fee.
Mar 22, 2014 | Hyundai Motor 2004 Accent
How doi install a radio after the original has been stolen and wires ripped out
You will need to buy an install kit even if they did. The back of new Radio's don't have anything but a plug to connect to. So the install kit will be needed to hookup the four {or just two depending on it's already installed options} speakers, the power, and ground. Plus the Antenna cable. They will all be color coded.
For example:
http://www.modifiedlife.com/1999-geo-metro-car-radio-wiring-diagram/
http://www.commandocaralarms.com/wiring/1995-/Geo/Metro/848.html
Nov 18, 2013 | 1994 Geo Tracker
I am looking for the FM mini antenna with push pull connector for ARS2I portable speaker system wth AM/FM radio and IPOD/IPHONE deck Acoustic Research - If you can not provide it please give me the...
This may be a pretty difficult task - since it is very small and looks similar to the AM antenna jack. We might think we have found the FM plug, but when fitting to the radio, learn that it is really the AM plug.
You may do better contacting Acoustic Research to obtain an FM antenna replacement via their customer support webpage. The product information page devoted to your ARS2I lists no accessories available. You can freely view / download the manual for the ARS2I here if you need a copy.
I hope this helps & good luck! Please rate my reply. Thank you.
Jun 10, 2011 | Audio Players & Recorders
How to install a new regulator?
You can buy the regulator at Home Depot. Just cut the gas hose off at the old regulator and put new regulator on with a hose clamp. $200.00??? Somebody is trying to rip you off !!!!!
Jul 23, 2010 | Weber Genesis Silver B Grill
The sides of seat fabric are ripped from the grab bar. what should i do? can i buy a new fabric?
Hi. Yes you can buy a new fabric at any fabric store and have the seat duplicated at any tailor shop. J.
Jun 29, 2010 | Toys
Antenna/Cable Connector partially ripped... Hi, everybody. Does anyone know how to fix a ripped antenna/cable connection? Thanks for the help. My TV Model is a Daewoo DTQ-13P3FC 13" TV for more details....
The cheapest way i can think of is open the tv and solder the ripped peice back on. That should work. If not you can go to radio shack and buy a new peice for it and install it by soldering the connections back on. Hope I could help.
Wayne
Jun 26, 2009 | Daewoo DTQ-13P3FC 13" TV
My 13" 2001 CRT Daewoo TV cable connection got loose
Yes you can buy the connector at radio shack and I do believe it requires a little bit of soldering but not much , the same thing happened to my tv and we fixed it up no problem.
Wayne
Jun 26, 2009 | Sanyo DS25390 TV
HANDHELD UNIT NEED ADAPTER TO GET DIGITAL SIGNAL NEAR KCMO
To connect a converter box to a handheld TV that has an external antenna jack, you need an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 12, 2009 | Casio TV-980 2.3 in. Handheld Television
No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
Feb 18, 2009 | Polaroid FLM-2632 Television
Digitial TV Converter
The antenna connects to the ant jack on the digital converter box. The cable you are describing goes from the tv jack on the box to the ant jack on the tv. If this does not work we will need more info. Hope this helps.
May 13, 2008 | Televison & Video
Apex Digital GT2011S 20" TV Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
