Question about Canon Rebel XT / EOS 350D Digital Camera
Can't take pictures up close on auto - Canon Rebel XT / EOS 350D Digital Camera
  • 1,170 Answers
You have to change the camera to 'Macro' mode. Then you can take really good close ups in auto focus
Posted on May 30, 2010
My camera turns on but it won't focus on automatic and when I press the button to take a picture it won't take one on manuel or automatic.
There may be a few things preventing the camera from taking a picture. I don't know the lens you are using but by chance does it have an auto/manual switch that has been switched to manual? Also make sure the lens is locked in position. The camera won't take a picture unless it has focus in the auto focus mode, this is normal. What are you trying to focus on? The camera auto focus system will search and fail to auto focus on surfaces that have little or nor contrast. For example glass, chrome, a blank wall, water, blue sky. Other conditions that auto focus fails is being to close to your subject, heavy fog, a dim lit subject, available light and night photography. Once the little green confirmation light comes on the camera has focus and will operate as it should.
Nov 27, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Nikon d80 will not take a picture the letter r flashes
your subject maybe very near that's why the auto mode prevents you from closing the shutter. R just stands for remaining images in the buffer.
Dec 28, 2009 | Nikon D80 Digital Camera with 18-135mm...
Pictures look blurry
try changing the setting it is in... or mabey it is in macro which is for close up shots.
Nov 11, 2009 | Canon PowerShot SD600 Digital Camera
COOLPIX 4600 CLOSED AFTER A PICTURE
Change setting to AUTO.
Use Flash.
Use High ISO
Press the buttons gently once and wait. Let the camera think , give it time to think.
Vitally
Jul 02, 2009 | Nikon Coolpix 4600 Digital Camera
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Macro setting
Try to take Macro picture in Auto mode.
Jul 24, 2008 | Sony Cyber-Shot DSC-P41 Digital Camera
Auto Focus Stoped Working
If the convergence is very far off the convergence ICs are bad and need to be replaced first. If the convergence is close and it wont correct it might just be an insect or some dust on the sensors at the 12, 3, 6 and 9 o'clock posistions behind the screen.
Jun 04, 2008 | Akai PTH5498 54" Rear Projection...
Close up shots for eBay pictures
Hi, you should have a macro lens shoot mode ( button with flower picture on reverse of camera) which allows you to take pictures close up in detail.
Jun 03, 2008 | Olympus Camedia C-60 Zoom Digital Camera
Picture won't take on auto
snoopytwo, jmv23 & guests,
Sounds like you have been taking photos in both auto & manual modes, make sure your f-stop is set at the range it needs to be to allow enough light for the camera to take the photo. Since the lens and the camera communicate, if the lens is closed down & not allowing enough light the camera will not take the photo - does that make sense - Look at the metering in auto mode and see what the camera says the conditions are for a specific lighting condition check to see if the lens has a aperture position for Auto, usually a dot on the lens ring to align with a setting in red or green (likely a F-22) depending on the make of lens, that has been moved to some place in the middle and not returned while trying other manual settings so the shutter won't release because the camera is told by the lens there is not enough light or slow enough shutter to take this picture.
randy320sgi
May 21, 2008 | Nikon N65 35mm SLR Camera
I am not getting good close-up pictures!!
I wish you have explained more about what you mean by close-ups. If you are talking about portraits: ...avoid flash - use some type of dim portable lamps ...use the optical zoom set to about 2X .....move back and reframe the subject ...set the camera to "aperture priority" and .....select f2.8 (to blur the background) If you are talking about table top photography: ...avoid flash - use some type of bright .....portable lamps ...use a tripod ...set the camera to shutter priority and select a .....slow shutter speed (to increase depth of field) ...focus on the exact spot you want to be sharpest
Sep 06, 2005 | Olympus Camedia C-765 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
