Question about Cowon System iAUDIO X5 MP3 Player
How long dose it take
I wanted to no how long dose it take for a file to download to my
iAUDIO X5. its way different to itunes were it tells you when it done.
  • Stevie
    Stevie Apr 08, 2008
    can someone please tell me please.
    Problem Solver:
  • 7 Answers
It don't take long, it depends on the file size you are putting into it, otherwise it might take a while based on that, or the amount of file you have in it, if it takes a while scrolling and you get a hour glass on your computer screen wait until it all loads up and it should work perfectly for you
Posted on Apr 16, 2008
Cowon iaudio 10 frozen
Hi. I had problem like this, now resolved. My device is iAudio 9+ otherwise it's not matter.
You can find some solutions on the web but... maybe you can not do proper result first or second time. It comes because of some differences for so lot of devices.
I used this method.
How To Recover your Bricked J3 using Tcctool iAudiophile net Forums
Only one way working for me.
1. Prepare drivers and firmwares. Tcctool and Windows drivers for USB flashmode. Latest FW for your iAudio from Cowon Korea site. Unpack all files/folders into special directory in root of your Hard Drive (c:\COWON for example).
2. Boot your PC in compatibility with non-authorised hardware mode. Press F8 button when PC loading and choose Drivers signature disabled mode.
3. Turn off your iAudio with reset button. Press both M(enu) and VolUp buttons and boot on power. Screen doesn't fire but device standing up in flashmode. Connect USB cable to device, then to PC. On Windows Device Manager you must find new Unknown Device. Install drivers manually from your specific directory.
4. Run on PC new task CMD, e.g. terminal window. Change work directory to your specific, f.e. cd c:\COWON
Run execution tcctool.exe -d cowons9 "name of your FW file"(without quotes).bin
Attention, your FW file (iaudio9P_fw.bin for me) must be in same directory with executable tcctool!
5. After flashing your iAudio must be connected to PC immediately as USB flash device. So you must copy all firmware files (named *.bin) to root of your Cowon device memory. Then reboot, your player must updating firmware and working fine. If still no, try use tcctool to boot on once more, then reboot normally. Copying FW files again doesn't required.
Hey you don't give up!
Mar 31, 2014 | Cowon Iaudio 10 16gb White
Laod movies onto my iaudio x5
u can use JETAUDIO converter. . . set your profile to iAudio x5
then click the convert button. . .
Jun 23, 2008 | Cowon System iAUDIO X5 MP3 Player
Apple ipod
You need to get ITunes, and then go to your limewire library, select the songs you want and press Enqueue and then press save file, save it to your documents and then go to Itunes, press file, import, then click the file you saved and it will automatically upload all the songs you saved, once your done plug your ipod into the computer and it will open itunes and download the songs to your IPOD
May 28, 2008 | Apple iPod nano
DOSES MY IAUDIO PLAY VIDEO
Yes it does, but the screen is small and the playback rate (15 frames per second) is slow for a fast action movie.
If you really want a video player with the same audio quality as the X5L, then take a look at the A2 from Cowon.
Apr 08, 2008 | Cowon System iAUDIO X5L Digital Media...
Iaudio x5 wont stay on
you should check if any wires are disconnected, and you might need to change the battery for it, if thats the case, sounds like the battery must of broke
Mar 06, 2008 | Cowon System iAUDIO X5 MP3 Player
Dropped iaudio X5 and it wont turn on
i found out a problem with it, i had the same problem if u have rockbox on their, u got to get rid of it, when it turns on plug the USB to the mp3 player, make sure it comes in the Drive of your computer, use a Windows XP, or any updated windows computer make sure that it's formatted into a FAT32 drive and format make sure u put the original firmware back into it, it can be downloaded from any Cowon Site, here is the steps if u want to know how to start it off Windows XP formatting instructions:
1. Connect your iAudio player to your PC's USB port and wait for it to detect.
2. Go to My Computer, click on Start then click on My Computer
3. Select the iAudio drive, then click on file and select format.
4. Click OK to format
Needs to be a FULL format and in FAT32.
after that is done, it will reset all the folders, and wipe off the hard drive and it should be back to normal, from then on it should work, if it doesn't try to use this site to request for a RMA repair service http://jetdb.jetaudio.com/RMARequest/Request.aspxand if u want to, u could try the Rockbox again if it is on it, but just know it's not fully supported by Iaudio...and ill give the Firmware link too if u want it [X5 Firmware]http://www.cowonamerica.com/download/iaudio_x5_jsfw.htmlor if it don't turn on possibily u can try to reconnect the power wire into the solder joints that should help with that issue, the power wire is red...that should help turn it on
May 03, 2007 | Cowon System iAUDIO X5 MP3 Player
IAudio X5 not recognised as removable drive
If there's no difference in the operating systems, or other software, a possibility is a faulty USB socket on the computer. Try another USB, or swap workstations... ;] hope it works out
Mar 21, 2006 | Cowon System iAUDIO X5 MP3 Player
Cowon System iAUDIO X5 MP3 Player Logo
52 people viewed this question
Top Cowon System Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cowon System Audio Player and Recorder Expert? Answer questions, earn points and help others
