Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Leaking water - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 5,911 Answers
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link has some other things you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
Another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 30, 2010
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
I have a 2013 keystone cougar 327res and the belly pan is full of water...where should i look for my leak?
This is not just for your camper, but general troubleshooting.
Drain the water from the belly pan. Hook up water supply to shore water source. With water source turned on, allow some time, 1-4 hours, and check if water has returned to belly pan. If water is present then the problem is with the fresh water system. If no water, either it is a small/slow leak or the problem is not with the fresh water system. Next test the grey water tank by pouring some red food color into the shower or sink drain. Flush it into tank with water. Again, wait for some time, maybe over night, and then check for red water in the belly pan. It may take longer for the leak to appear as the grey water tank does not have pressure. If no water, check the black water tank with green food coloring and same technique. If there is colored water, red or green, in the belly pan, then the leak is with associated with the grey or black water tanks. If no water is present after these tests, then the leak may be very small and it may take days or weeks to have water re-appear. In any event, clear water is fresh water system, red water is grey water system, and green water is black water system. With any of them, checking the tanks themselves and all pipes and connectors to/from should find the leak source. The last possibility is that water is entering the belly pan from a roof or vent leak. Check to see if water returns to belly pan after a good rain. If so, the water may be clear or slightly dirty. If it is a roof leak, I have found the best repair is to use Peel and Seal roll roofing It is light weight laminated aluminum and self sticking. Cutting and applying narrow strips 4-6" wide, will seal any caulked area. It costs $95 (3' x 33') at Lowes. A 30" motor home can be completely covered with three (3) rolls, in half a day. I have re-topped 5 motor homes (one 7 years ago) and no more leaks on any of them. The product was developed to seal the roofing joints of mobile homes. Topping should last 15+ years.
Oct 05, 2016 | Keystone 2013 Cougar 327RES
Repair a cold water leak at the bottom of my water heater
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
Dec 02, 2014 | Water Water Heaters
Ge smart water heater
Depends on source of leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Leaking-water-heater.html
Some leaks can be repaired, while other leaks indicate that tank is rusted and needs replacement.
Gene
h
Aug 10, 2013 | Water Heaters
Leaking water from top
1) Copy following link for troubleshooting leaking water heater:
2) After opening link to identify problem, add a comment and give brand, type and approx age of waTer heater for more possible help.
Feb 19, 2013 | Water Heaters
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal De
