Question about GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
I have a GE Spacemaker microwave JVM1440WH. How do I remove & replace the surface light underneath the oven?
  • GE Master
  • 9,047 Answers
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
Posted on May 30, 2010
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light that is inside the GE Spacemaker microwave?
with cord unplugged you can remove the main control panel and access to it
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave. One of the lights does
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,082 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
