Question about Garden
Trimmer won't start...no compression...oil ran dry once last year. Engine leaked oil for a year. I changed valve cover gasket and engine started once, and has not started again. Rope pull has no tension like there is no compression in engine.
  • 10,865 Answers
I believe you have properly diagnosed your problem as one of no compression. It is time to replace this trimmer with a newer one or a new one. Shop around as some of the sales are on right now. J.
Posted on May 30, 2010
Is there a sensor that will make car use oil,not start,low compression turn over like it jump time
Cars only lose oil for two reasons, wear and leaks.
Wear on piston rings especially the oil scraper ring which is the bottom one on the piston.
Wear on valve stems which have oil on one end of the valve stem and the combustion chamber at the other.
Leaks from any part of the engine, usually head gasket, rocker cover gasket or sump gasket.
Jan 27, 2016 | Cars & Trucks
My infiniti is consuming oil at least 1 qt, i have to refill every week. what can it be somepeople have telling me the PVC valvue, the oil pressure o rings, bad pistons and people telling me that they...
1 a simple compression test will tell you if the rings and valves are bad. thats where you start.. 2 it could be an oil leak under the vehicle , you will see a black spot. do this first it only takes a look whee you park it on dry clean pavement or place a clean piece of cardboard under it.
Mar 02, 2015 | 2005 Infiniti G35
Smell cabin
A modern, well maintained vehicle's exhaust is virtually orderless once the catalytic converter has fired up. What you could smelling is oil leaking from the engine, for instance, from the valve cover that then drips down onto the hot exhaust where it vaporizes. That oil vapor is then ingesting into the passenger compartment through the fresh air intakes. Try airing out the cabin and then set the ventilation controls to recirculation mode to see if the problem persists. Also, the oil vapor will only happen when the exhaust is hot. So if you don't smell it when you first start the engine, that could be confirming this cause. Look at your engine and see if you see oil and dirt oozing from the valve cover gasket. You can try to tighten the oil cover fasterners to see if it stops the leak, but the best approach would be to replace the valve cover gasket.
Oct 02, 2013 | 1994 Honda Accord
Burning oil
Assuming its a briggs and stratton
kohlers have hydraulic valves
check its not overfull of oil
smell the oil does it smell like gas?
if so remove carb. clean thoroghly and drain and refill oil
check valve clearance .004 both exhaust and intake (cold engine)
valve cover gasket could be leaking on the exhaust
could have a partially blown or blown head gasket also
Jun 13, 2013 | Cub Cadet Garden
After changing plugs valve cover gaskets it sarted up smoked badly i cut it off started up the next morning it ran for two seconds cut off i pulled the plugs theyre wet new plug car just spinns over...
SMOKING COMING FROM OIL SPILLED ON THE ENGINE AND MANIFOLD WHEN YOU CHANGED VALVE COVERS.OIL PROBABLY GOT IN PLUGS HOLES FOULING OUT PLUGS. SPRAY PLUGS WITH CARB CLEANER OR BRAKE CLEANER TO CLEAN THEM.DRY THEM. REINSTALL PLUGS BACK IN THE ENGINE.CLEAN OIL OFF ENGINE AND MANIFOLD SO IT WONT SMOKE. CRANK ENGINE SHOULD BE OKAY.
Mar 09, 2010 | 1999 Lexus Gs 400
Mx5 mk2.5 slight engine oil leak.
Can you tell us more?
How many miles on the car?
Which side of the engine area? Drips after you park etc?
Oil ever low? If so how often do you ad oil?
Any visible oil on engine and bay components under hood?
likely areas for oil leaks may include depending on model and make:
Oil pan gasket seal.
Oil pressure sending unit.
Oil filter installed dry or over tightened at your last oil change.
Oil drain plug loose or plug gasket needs replacing.
Valve cover gasket needs replacing.
Crank shaft seals need replacing.
Distributor seals need replacing.
RTV gasket sealer beyond expected life and need replacing for other engine components, inspection plates or covers.
Sep 21, 2009 | 2002 Mazda Miata
Oil Leak
Take the car to a car wash and power wash the engine. Do this ONLY with a cold engine. And be prepared to have problems with it starting as water get's into the electrical components. Take some WD-40 with you to spray inside distributor caps, on spark wiring, etc. to get the engine running again.
Then check the engine weekly to see where the oil is coming from.
Jan 23, 2009 | 1996 Volkswagen Jetta
Engine warms upthen smoke rises from side of engine
You make have a valve cover gasket leaking. After 2 years of sitting it could have dried out.
Bill
Nov 19, 2008 | 1996 Ford Taurus
1996 honda prelude oil leak
did you check the steering pump, AC compression pump, etc or other engine components ? it could be something other than the engine.
Nov 18, 2008 | 1996 Honda Prelude
Garden Logo
175 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
