Question about Frontier Gas Grill
Gas does not come out from burners...It seems
I cleanded the grill tody and now the gas does not come out from burners...It seems clogged. How can I make it work so I can grill?
  • 10,865 Answers
Hello. Use a piece of fine wire to clean each of the jets in the burners if they are clogged. J.
Posted on May 30, 2010
  • 8,404 Answers
Blow it out with compressed air (canned air - air compressor or blow it out with the back side of a vacuum cleaner. Spiders love the smell of propane gas.
You do have fuel ... right? and the valve is on ... right?
Hi, my model 4651330 worked great the first time i used it. Now I can't get the grill to completely light. It seems like the gas is not being pushed through.
Turn the gas cylinder OFF and disconnect it from the valve. Wait 5 minutes and reinsert and screw the tank valve in. Once it's completely seated, turn the valve ON VERY, VERY, SLOWLY (Slow motion, slow). One the valve is fully open, light the burner. Have the burner flames returned to normal? If so, you just solved the problem. If it didn't, turn the tank OFF and remove it. Then remove the cooking grates and lava rock, if you're using lava rock. Inspect the burner closely, as it may be clogged. It may even require removing the burner from the grill to clean it properly. Also, check the venturi valve. That's the thing on the side of the grill tht's part of the burner. It mixes air to the gas, so that there will be complete combustion. The venturi valve may have been moved by accident or it's clogged. The correct position of the fan like opening is 3/4's of the way open.
I have assumed you have made sure there's still gas in the cylinder.
Hope this helps you to troubleshoot and solve the problem.
Jun 17, 2011 | Char-Broil Tabletop 4651330 (LP) Grill
Good Afternoon..On my Tuscany grill only 1 of the 3 burners work. looking from left to right, the left one does not work at all and the middle burner barely. No smell of gas on the 1st and very little in...
Sounds like the offending burners need to be removed, checked thoroughly for clogs and particularly the venturi valve on each burner. And while you have them out, remove the burner orifice of each burner and look for clogs.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 19, 2011 | Altima Technologies AGR48PF Grill
The burners are not burning properly. The gas line seems to be clogged. Do you have any troubleshooting suggestions?
Replace the hose and regulator if this is an LP grill...... or just the regulator if this is a NG grill.
Jul 03, 2010 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Viking grill burner is clogged and fire is shooting out of knob. How do I clean my grill from excessive grease.
Is it still under warranty? I'd call Viking or a qualified repairman to fix it. If your burners are clogged, the flames should be coming out the venturi tube and flaming towards the gas valve knob. If the flames are coming out of the gas valve itself, then it will need to be regreased. If the burners can be removed without too much trouble, soak them in the sink with hot water and dishwashing detergent. Be sure to remove the knobs, so no one turns the gas on without the burners connected. If it's difficult, call a repairman.
May 12, 2010 | Grilling
Grill/griddle burner not getting hot enough.
are you able to adjust the flame ? has it always been this way?
Dec 29, 2017 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Wont get hot fast takes for ever
It's most likely a blockage at the burners. Make sure the burners are clean of any loose rust, dirt or spider webs. Grease drippings can also clog the burners and reduce gas flow and flame.
Apr 21, 2010 | Weber Genesis Silver B Grill
My grill does not seem to be getting gas. I put a new propane tank on and still nothing. It seems to be clogged somewhere? Is this possible. I bought a new tank hose last season could that be bad? The...
Take the tank loose from the grill and open all the burners. Then close the burners and reconnect the tank.
SLOWLY open the tank just a little bit and light the burners with a stick lighter. That's what I do. Those new tans have a safety device in them that locks off the gas if the tank tilted even slightly or the gas valves are opened too fast.
Apr 11, 2010 | Vermont Casting The Extreme VCS5005BI...
Not getting enough gas
Regulator bad, its the hose conncting to tank-
Jun 27, 2009 | Kenmore 505 sq. in. Cooking Area Gas Grill...
My charbroil grill isn't running at full power
Your venturi could be clogged up. clean the burner holes with a straightened paperclip, then take the burners out and do the same to the venturi that deliver gas to the burners. If that doesn't do it, you may have a bad regulator.
Feb 26, 2018 | Char-Broil Grilling
Frontier  Gas Grill Logo
160 people viewed this question
Top Frontier Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frontier Grilling Expert? Answer questions, earn points and help others
