Question about Frigidaire ATF6000ES Front Load Washer
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
  • Frigidaire Master
  • 43,501 Answers
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machinedaughter washed a feather pillow which fell apart - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 30, 2010
Washing machine clogged with feathers
The pump is plugged most of the time it is under the washer take the hoses off and clean it out. Make sure to try to get ant feathers out of the hoses also
Sep 05, 2012 | Washing Machines
MY FRIGIDARE INFINITY WASHER STOPPED SPINNING AT ANY CYCLE...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2011 | Whirlpool GHW9200L Front Load Washer
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
Duck Feather Pillow In Washer. Feathers everywhere. door will not unlock or drain water. help
Pull off the lower front panel and reach up on the right of the washer to the door lock assembly you will feel a tab hanging down pull it and the door will release. Clean out the drain filter and pump hoses etc. Rise it out and you may have to clean the filter a few times.
Nov 29, 2010 | Maytag MAH8700A Front Load Washer
A feather pillow busted during the cycle - What do I need to do to prevent damage?
either you have overloaded the machine or else your spin speed was set on high, lower it down and it should not happen next time.Make sure there is nothing broken inside the tumble or the spinning area...
Jan 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
WONT DRAIN
clean the pump and also make sure that the pump motor is powered during draining
May 30, 2009 | Frigidaire GSTF1670A Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
I washed a feather pillow and it busted, now it wont pump water out.
There is a filter down in the bottom front of the washer (below the drum) that is probably clogged with feathers. It is a pain to get to, but once you get it cleaned out, the washer should spin and drain without problems.
Oct 25, 2008 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
224 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
