Question about XM Radio XM Direct 2 Mini-Tuner Car Kit for XM Ready Aftermarket Radios Satellite
I AM NOT GETTING A SIGNAL - XM Radio XM Direct 2 Mini-Tuner Car Kit for XM Ready Aftermarket Radios Satellite
    Problem Solver:
  • 10 Answers
Idk
Posted on Jun 02, 2010
Signal lights nor turn signals work. new bulbs an flasher switch
It could be the turn signal switch. Test to see if current is getting to the turn signal switch and if it is then test to see if current is getting from the turn signal switch to the flasher.
May 26, 2015 | Cadillac DeVille Cars & Trucks
SAMSUNG LE32R87BD tv getting no signal
Tvs on mobile phones require settings about the location before they can recieve any signal. Review the tv settings on your phone and select your location. If problem persists, get in touch with me again. Thank you.
Dec 30, 2011 | Samsung Cell Phones
Macvision MN2607 signal problem
Hi and thank you for using fixya:
If you are having trouble getting signal please check if any object is obstructing the view of the sky from your signal receiver.
Thanks good luck
Jul 26, 2010 | Nextar MacVision MP1607 Car DVD Player
Getting a no signal when hoioking up to video card.
hook a different montor up to the same card and see if you get a signal. if you do change the input on the monitor not getting a signal. if this does not make the monitor get a signal your video input on the monitor is bad and needs o be replaced or repaired
Dec 26, 2009 | AOC Monitor
Getting input signals into ECM but no signal to ignition module. Will not start.
You really need to have a look at the signal with a scope as you may be getting a signal but it may not be the correct signal. Are you measuring this with a multimeter..? As the signal is amplitude dependent, measuring the voltage is not going to tell you anything. I would only suspect the ECU last as they are reliable. Also, do a continuity test on the wiring from the ECU to the ignition module etc..
Dec 02, 2009 | 1995 Volvo 960
Car won't go in drive without using override button
does your brake lights work? it's sounds like the shift lock solenoid isn't working it could be not getting a signal from the brake light switch or if it is getting signal then the shiftlock solenoid is bad but make sure the solenoid is getting a signal from the brakelight switch first
Nov 07, 2009 | 2003 Toyota Corolla
I am getting a (weak or no signal)
Hello glc_11489,
Have you tried to use an amplified antenna? I have found that this works very well.
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jun 12, 2009 | Philips Magnavox 20MT133S 20" TV
Jeep dont start do noting Lerado 93
check and see if you are getting spark. If you aren't getting spark, sounds like you might have a problem with the crank sensor. The car won't give you spark if you aren't getting a crank signal, oil pressure signal, and it will take a long time to start if you aren't getting a cam signal. If the car is getting spark contact me back and we will go from there. Hope this helps you
Jan 19, 2009 | 1995 Jeep Grand Cherokee
XM Radio XM Direct 2 Mini-Tuner Car Kit for XM Ready Aftermarket Radios  Satellite Logo
143 people viewed this question
Top XM Radio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a XM Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
