Question about Yamaha 4500 Watt Electric Start Generator - EF5200DE
Had to tickle the throttle on my yamaha 3500 watt
Had to tickle the throttle on my yamaha 4500 watt genny to start,but it always ran flawlessly untill now. acts like it's not getting gas but there's plenty in the float bowl,and all looks clean.
    Scholar:
  • 142 Answers
You should have automatic or manual choke control. Try to find it and open it during start. After that you can close it if stable work is achieved.
Posted on Jun 13, 2010
My Oman generator overheats and shuts down if I plug my battery charger in and have my air conditioning on and or coffee maker
to start with with an air conditioner running (2000 +watts ) plus a coffee machine (1500 watts ) you are looking at 3500 + watts of power used from the generator
the genset has to be of a minimum of 4500 watts to run full time with out over heating
never mind what the rating says on the side, that rating is surge rated and the duty cycle is around 500 watts less than that figure
So if your gen set is 3500 watts the power is at surge power and that will overheat the genset
Of course you haven't mentioned the rating of the set , but overloading is the main reason for over heating
Jun 06, 2016 | Electrical Supplies
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
Yamaha EF4500Ise Gennerator won't produce power.
Doe's it have a thermal couple on it? If so it could be bad and when it heats up it is killing your power.
Sep 18, 2012 | Yamaha EF4500iSE Generator 4500 Watt...
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Aug 25, 2010 | Yamaha 4500 Watt Electric Start Generator...
Yamaha 6600de generator dies 3 seconds after starting
When you pull the bowl off of your carb is it clean? If not you have some contamination possibly inside. You might want to remove the carb and blow compressed air through all the vents a ports.
Sep 24, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Yamaha 4500 Watt Electric Start Generator - EF5200DE Logo
144 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
