Question about GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL JVM1443 stays on when door is closed
Hi - I've had a GE SpacemakerXL JVM1443 for about 4 years. Suddenly last week, every time I shut the door, the microwave light stays on as well as a humming noise. I think this is just a fan and not actual heating. The microwave still works, but i have to unplug it between uses or it will just stay on. Any ideas?
  • GE Master
  • 9,047 Answers
That's almost certainly a failed primary interlock (upper door switch) or its mount is bad.
See our file on info on door switch diagnosis and replacement.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
GE SpacemakerXL JVM1443 stays on when door is clos - mini_manual_behind_grille_small.jpgf1b3b03.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 30, 2010
GE Microwave will only run about 3 seconds, then shuts off. I've unplugged, let it sit and tried again. Same thing. Help!
I have a workaround for you, that works for other brands. I am not sure if it will work in your case though. Pls try it:
- It seems that the door closing sensor is not working well, so it might think that the door opened.
- Once you have this problem, open the door and then close it again.
Normally it should work...
Nov 21, 2012 | GE Microwave Ovens
I have GE Profile microwave model PVM1870SM1SS and last week while running, suddently it shut off. There is no power, display buttons and stopped running. Please advise.
From the description a major part has failed, the magnetron is suspect because it suddenly shut down in cycle, if the unit is less than 7 years old it probably has a inverter board and tends to fail, also there is the possibility the keypad control board has stopped working. The microwave in my opinion is worth getting checked out and repaired, but it will be expensive.
Apr 03, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Heat won't work on ge spacesaver microwave oven --what to do from
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ioi
Dec 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
183 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
