Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
While water is being dispensed through the cool water outlet, water leaks thru the flexable line at the bottom of the freezer compartment door. Whats the problem, and how can it be fixed?
  • 1 more comment
  • Mike Smith
    Mike Smith May 30, 2010
    Model number needed to help you .
  • louie_juanit May 30, 2010
    GE refridgerator Model TFX24S
    GE refirdgerator Model TRX24S
  • GE Master
  • 1,606 Answers
Due to water comming from the bottom of the dooe , you will need to replace the door water line . Pt # WR17X10206 is the replacement line . Remove the upper portion and " feed " the new line down thru the freezer door .
Posted on May 30, 2010
Water dispenser does not work, any time it is used water just drains out of bottom of freezer area onto floor. Ice cubes works
Hello Melissa;
My name is Peter. I am a retired field service refrigeration technician.
I am sorry to say you have a serious problem.
The water supply line to your ice maker runs up the back of your refrigerator from the ice maker solenoid. It is a separate water supply line.
Your water dispenser water line runs from the water dispenser solenoid under your unit and up from the bottom of you freeze door.
You have a plastic tubing leak within your freezer door. Calling a service company to replace the freezer door tubing - a good service technician would not replace the tubing - the damage has already been done.
The insulating material in your freezer door is soaked. The water in the door will cause the door liner to expand and crack. There is no way to completely dry out the insulating material.
The only fix is to replace the freezer door. So, $300.00+ for the door and $150.00+ for the service tech. No, a hair dryer will not do it.
May I suggest:
1.) Remove the bottom toe plate (Kicker plate) in the front of your refrigerator.
2.) Turn the leveling screws counter clockwise so you can pull the refrigerator out to get behind it.
3.) Unplug the unit.
4.) Remove the screws from the bottom cover.
5.) There are two connectors to the solenoid valve to the water dispenser. It is the larger diameter tubing running under your refrigerator.
This will disable your water dispenser. If you see cracks on the inside of your freezer door, seal them with a high temperature silicone adhesive.
If you elect to purchase a new unit, check out Sears Outlet (Scratch & Dent) Stores.
May 08, 2015 | Refrigerators
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
Water accumulating and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Water leaking out the bottom of the freezer. It is running forward from the back of the freezer compartment. Could it have to do with the ice maker, or the water coming into the door?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 29, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
I CANNOT GET WATER THROUGH THE DOOR, HAVE WATER TO THE LINE AT THE BOTTOM OF THE DOOR
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Dec 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
IWater does not dispense.
Good day,
The hum is normal. That's the water valve in the rear of the machine being activated.
Lots of plumbing to be checked.
Water line starts at the dispensing outlet in the door, and runs thru the door to the bottom of the hinged side.
From there it goes to the filter,
'From there it travels under the machine into the cooling reservoir mounted back of the fresh food section behind the crispers.
From there it travels back out and runs to the water solenoid mounted on the back rear of the machine.
One of these lines or their fittings has failed.
It's a look-see repair.
Also, there is a remote chance the water line running inside the freezer door froze, causing this problem, and would require the machine be shut down (unplugged) and the door be allowed to defrost completely.
Nov 16, 2009 | KitchenAid Refrigerators
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring2.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Oct 15, 2009 | GE GSH25KGR Side by Side Refrigerator
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Water leaking from inside door
the water line for the water disp runs in a chase that goes up thru the bottom hinge of the refrig door. SO DONT PULL YOUR DOOR APART! you can order a new water line thru frigidaire and replace the part by removing the water dispenser housing on the door and pulling the line thru the door then inst the new line in reverse. if it looks like too big a job then get a reputable company to inst it for you.
Jan 21, 2009 | Frigidaire GLRT188WD Top Freezer...
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
