Command Prompt shut down my computer
Hi!
If i open command prompt, my computer shuts down. Please help!
Thank you!
  • 2 more comments
  • Anonymous Oct 05, 2008
    the same happens to me
  • zanpakutou Nov 24, 2008
    I had Avira Antivir installed in my PC. I reboot my pc in safe mode then turned off system restore. I ran the software (full scan) but detects only 1 warning (file wasn't scanned) and no virus was found. I reboot my pc in normal mode then I run CMD and still my keeps rebooting.
    Please assist.
  • biksbikalpa Dec 22, 2008
    whenever i open my pc this error occurs:-
    "THIS SYSYEM IS SHUTTING DOWN.PLEASE SAVE ALL WORK IN PROGRESS AND LOGG OFF.ANY UNSAVED CHANGES WILL BE LOST.THIS SHUTDOWN WAS INITIATED BY RAHUL
  • Anonymous Mar 19, 2009
Had the same problem and found an exact solution here...
might as well try it on yours
http://www.techykid.com/virus/auto-shutdown-virus.html
thanks
Posted on Apr 01, 2009
    Genius:
  • 2,785 Answers
Your pc is infected by viruses please update your anti-viruse then disable system restore and boot in safe mode and do a system scan
Posted on Apr 08, 2008
SOURCE:
How to Shut Down a Work Station Remotely (Windows)?
If you are using the Remote Desktop Connection option of Windows, then the only option it provides is to logout. If however, you can get to the Command Prompt (Admin), then you can use the 'shutdown' command from the command prompt window. Type in 'shutdown /?' to see a list of options.
Oct 20, 2016 | Microsoft Computers & Internet
How do I restart or reboot my whole system and start fresh.I have a Dell latitude D430
Dell not given facility to reboot. But command through you can reboot . To access the command prompt window from Vista or Windows 7:
  1. Go to the Start menu
  2. Type cmd in the Search field
  3. Press Enter
On a Windows XP computer:
  1. Click the Start menu
  2. Choose Run
  3. Type cmd
  4. Press Enter
From an open command prompt window, you can type shutdown, and then the option you wish to execute.
To shut down your computer type: shutdown /s
To restart your computer type: shutdown /r
To log off your computer type: shutdown /l
0r
press down window key with and two time press "U" key.
Sep 19, 2013 | Computers & Internet
Can i restore my compact presario sr1503wn with out a disc?
Hi
1. Click Start
2. Click Shutdown/
3. The "Shut Down Windows" dialog box will be displayed/
4. Select "Shut Down" from the me
5.Start the system again.
6. When the Red Compaq logo appears press F8 repeatedly until prompted with the "Windows Startup
Menu"
7. Select option 6 (Safemode Command Prompt) by pressing the down arrow key until Safe Mode Command Prompt is highlighted
8. Press Enter
9. At the C:\ prompt type D: and press Enter
10.At the D:\ prompt type CD CPQS and press Enter
11.At the D:\CPQS prompt type XQR press Enter
Method 2:
1. Click Start 2. Click Run 3. In the "Open" box type C:\CPQS\QUICKSR\FRESTORE.EXE Performing these steps should resolve this issue.
Also check his link if it helps:-
http://social.microsoft.com/forums/en-US/genuinewindowsxp/thread/95860a8d-3a44-43a3-b26f-2436bdf2bfc6/
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | HP Compaq Presario SR1503wm PC Desktop
My Acer Aspire 5810TG does not shut down on battery. No problem on AC
Until you can locate the underlying cause of the problem (could be mechanical, or your particular battery power configuration settings), you can try this:
Open up a command prompt window (Start Menu > Accessories > System; or, Start Menu > Click "Run" > Type cmd in the box and press enter)
Once the command prompt session has opened, type "shutdown -s" (without the quotation marks) and press enter.
You should see a box pop up warning that shut down will occur in 30 seconds. After the countdown completes, your computer should begin the shutdown routine. This command works for restarting the computer as well, just change "-s" to "-r"
Jun 01, 2011 | Acer Aspire 1642ZWLMi Notebook
I need to know my ip adress and all that stuff?? help please
Inorder to find the ipaddress of your computer follow these steps,
1. Click on start? Go to All programs? Accessories?Command Prompt
2. You will find a black screen which is the Command prompt
3. In the command prompt you will find a blinking cursor , there you type in "ipconfig/all" (without cotes)and hit enter.
4. You will find ipaddress, subnet mask, default gateway , mac address/physical address and all other information of your comp.
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | Computers & Internet
How do i shut down comand promptsw on my computer
Hi Good day!!if you are using windows go to command prompt. press windows logo key + r to display run dialog. type cmd and click ok. in the command prompt type the following commands and press enter: shutdown.exe -s -f -t 0
-s = shutdown
-f = force shutdown closing all programs
-t = time in millisecond
0 = now you can change this no. to schedule your shutdown.
for ubuntu open terminal and type -sudo shutdown 0 you can change the 0 if you want.
Hope my solution help you!!
Oct 16, 2010 | Computers & Internet
My computer will not install updates. it says it is installing them after it shuts down but they never install.
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Regards,
Om
Oct 11, 2009 | Microsoft Windows XP Professional
Computer problem
that is your DOS prompt
Try typing at the black cursor (chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
If that does not work
Shut down PC
F8 on boot get back to Advanced boot option
SAFE MODE WITH NETWORKING
Sign in as ADMIN or Owner
say yes to get to Desktop
Once you get to the Desktop
(Windows XP)
Start>RUN>CMD (This will be the command prompt window}
(chkdsk /r <ENTER> <Y> <ENTER> Restart the PC)
(Vista)
Start>Start Search>cmd>(above) Right click on CMD>Left click(RUN ADMIN) (This will be the command prompt window)(chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
Jan 23, 2009 | Intel D845GVSR Motherboard
Acer aspire
HI!
You can not do something, if your computer will continuosly shutting down as you turn it on. so first and foremost, if it is still applicable, try to repair your OS, by rebooting on its original OS.
If this is not possible, run your pc, on SAFE MODE with COMMAND PROMPT, and try to copy the file you want to transfer from drive C to drive D. And to have a guide to do so, as you get in the command prompt, type xcopy/?
Dec 31, 2007 | Acer Aspire 3000 Notebook
Shut down problem
If you can go to Safe Mode, try to open command prompt from there. Have your Winxp Cd ready. Type sfc /SCANNOW
Aug 20, 2007 | Microsoft Windows XP Professional With...
Open Questions:
Computers & Internet Logo
1,903 people viewed this question
Ekse
Alun Cox
