Question about Sylvania SRCD227 27 in. TV/DVD Combo
When tv is pluged in and turned on it shuts of after a few seconds
    President:
  • 1,099 Answers
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive High Voltage were detected.
Posted on Jun 01, 2010
W KDS-R50XBR1 50 in. HDTV Television standby light blinks red 3 times
Something you might want to look at:http://sites.google.com/site/sonylcdrptvproblems/lamp-overheating-issue
Apr 06, 2012 | Sony KDS-R50XBR1 50" HDTV
My television suddenly turned itself off while switching from video to hdmi. Now it will only turn on for a few seconds and shows a "no signal" message, then shuts itself off.
We have a 42" Model XV42L HDTV10A 100-240V,2.5A,50/60HZ....when we turn the TV on the screen is flickering and then shuts itself off....sometimes it will come on for a few seconds and then shuts off
Dec 16, 2010 | Vizio 42 in. LCD TV
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Tv just shut off, so i un-pluged it for a few, turned it back on green light flashes for about 20 seconds then red lamp light flashes, tell me the bad news
Yup.. it's bad.. sounds like a typical Switchmode power supply fault or some other fault that is shutting down the PSU, to stop any more problems and prevent a fire etc. I guess it cannot hurt to obtain a firm "Quote" for repair from a reliable service center?
Mar 04, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My tv turns on then shuts of with a flashing light.
Ur hight voltage transformer(call the FBT Flyback Transformer it dead or cold soldiers.The big black block of plastic with a red wire with a cap hook to the CRT(the tv tube).
Jul 09, 2009 | Sony KV-32S45 32" TV
Turn on the tv a few seconds later it shuts the power light blink
Replace both of your convergence ICs they are STKs big black ICs will have part number on them.
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Local tv repairman
Check nearest local TV repair shop in Fixya TV Repair Shop Directory.
Jun 17, 2009 | Mitsubishi Televison & Video
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Sylvania SRCD227 27 in. TV/DVD Combo Logo
77 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
