Question about Marantz CDR420 CD Recorder
Muddy playback of MP3 recording
When monitoring the recording, it sounded great but played back muddy. We only had the option of RCA cable for aux. Is there a way to improve the recording quality; is it a playback problem; what to do in future? Microphones were connected to a self-contained Bosch system, not a mixer
  • cattwitch Jun 04, 2010
    I want to know what can be done to help the poor recording - to improve it.
  • 2,069 Answers
Do you have the ALC feature (Automatic Level Control) turned on. If not, set it on and check.
Posted on Jun 04, 2010
    That feature was on that setting for the recording
    Later recordings - which turned out better - were placed on Limiter.
    We believe the problem occurred because the input was ONE RCA input and the internal recording setting was set at Stereo. The L+R setting was used, too. So we think there may have been a conflict. It does not fully explain why the monitoring was good and the playback was bad...
    Still, my main concern now is how to salvage - even slightly improve - the muddy recording so that the voices are more easily understood. If possible.
  • Muzahura Frank Jun 04, 2010
    fixing your already recorded file may not be possible because of the GIGO ( Garbage in = Garbage Out) aspect. however, you could also do it with the ALC feature off and set it up manually by adjusting the controls. and like you noted, the used audio lines could have caused that distortion. download this guide if you don't already have it.
    regards
  • Marantz Master
  • 3,866 Answers
Sounds liek the recording was not direct in a sense from computer to CD quality so the bit rate suffered.. I would suggest a computer in the middle of this recording env. to adjust bit rate a good bit rate would be 128k at least for the minium.
A Muddy playback was probably from a muddy type of recording, best results is you a computer to upscale it to a CD quality solution next time.
Thanks and please do click the accept buttonf for my efforts.
Posted on May 30, 2010
  • 1 more comment
  • cattwitch May 30, 2010
    Bit rate on recorder was set to 128. Is there anything we can do to reduce the muddy quality of current recording (salvage)? How can we use a computer to do that? Have looked into some audio programs to reduce noise, but noise is not really the problem.
    The Bosch mic system was direct into the recorder.
    Other advice that might make your first email comments more useful?
  • Grand Canyon Tech
    Grand Canyon Tech Jun 04, 2010
    I would use the computer via a audio out or capture device to salvage. See the program you might been using is not one of quality, more like studio.
    let me know i will give you more ideas.
    I would need a bit more info, to be sure.
    The recording was direct to the Marantz. It was in MP3 format and can be loaded onto a computer. what kind of "capture device" are you talking about?
    I tired some free downloadable programs that claimed they could fix everything but they did not improve quality - it was more like trading for a different level of muddy or went to scratchy.
    Thanks for more info to come...
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
No sound when I play back a commercial DVD
May be something wrong with HDMi cable.
Is there sound when play VCR?
Please test - check with regular RCA cable AV out.
If OK. Next step Replace HDMI cable.
IF No sound with RCA cable look like need replace VCR Main Board.
Feb 20, 2015 | Panasonic DMR-EZ485VK DVD Recorder/VCR
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
Muddy prints
I have the R2400 and the photo prints look muddy. I have tried the same picture on another printer and the colors are vibrant. Why the muddy pictures on such a nice printer?
Mar 23, 2010 | Epson Stylus Photo R2400 InkJet Printer
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
I need advice on how to connect my very old BOSE 901 (with active eq) to this device: Martin Roland MA 3000K I see pre-out and pre-in but cannot locate main-in. Please help here is the back of its image:...
As you probably know, the Bose 901 Active EQ is there to modify the frequency spectrum fed to the 901's so they will produce a flat response. Without it, they sound acceptable in the midrange but lacking in bass. Since they have no woofers or tweeters, the modification is drastic and should never be applied to non-Bose-901 speakers or they could be damaged.
This setup should work for mixing and playing but I'm not sure if recordings directly from the unit's REC Out or Line Out would have the Active EQ effect on them. You'll need to perform a few tests to see how it all works for playback AND recording.
Remove the jumpers for Pre In >> Out
Insert the Active EQ in their place by running:
1. RCA cables from Pre Out to the Active EQ In (From Aux, Tape Out)
2. RCA cables from the Active EQ Out (To Amp, Tape In)
Use ONLY 901's on this amp with the EQ.
The Bose Active EQ has its own Tape Rec/Monitor loop to replace the one it normally occupies in a typical receiver application, so if you wish to record your mix you should use those connectors for your tape deck and there will be no problems with the Active EQ effect being recorded. The Monitor Tape/Source switch on the EQ functions just like a typical Tape Monitor. For playback of the recording, switch it to Tape.
The manual, available at http://lib.store.yahoo.net/lib/acekaraoke/MA3000K.pdf
doesn't get into any detail on the innards of the mixer.
In a typical integrated amp or receiver, the jumpers removed are between the Preamp Output and the Main Amp input, but BEFORE the amp's volume and tone controls, so manipulating them would not affect a recording. You should experiment with it by making recordings through both and adjusting speaker volume to see if it changes.
I would be curious to know what the functional difference is between the designated LINE Out, REC Out and PRE Out jacks in that regard. Normally, Line Out and REC Out will not vary with amp volume, but I expect in this mixer it does, or you wouldn't be able to control the volume from it. Experiment.
Of course, you probably want the mixed effects to be recordable, so I assume they'll appear at all outputs. Play back the test recording (at an initial low level, just in case) and see if you can detect an exaggerated low end (due to the 901 bass boost being applied in recording AND playback through the 901's. If the recording volume doesn't vary with speaker volume and the playback sounds as flat as the recording you're good to go.
If there is are volume variations or an additive effect, you may have to draw the REC Out to the deck's input and run the deck's output to the Tape In on the 901 Active EQ, monitoring only on deck playback.
Dec 02, 2009 | Bose 901 VI Main / Stereo Speaker
Mp3 connect yamaha rx-v995 ---> muddy sound
Try getting into the configuration menu of the MP3 player and adjust the output controls for external devices....it sounds to me like it might be too high and/or the wrong output decoding.
May 09, 2009 | Yamaha RX-V995 Receiver
Record/playback
Run audio INTO the MD play in the L & R IN jacks.
For playback, run (RCA phono plug cables) from the L & R OUT to your amplifier AUX or TAPE inputs. Try playback working first, then add the record function.
Mar 26, 2009 | Audio Players & Recorders
Muddy image on screen and recorded
You are in luck. Sorry for the trouble but your model Elura 50 still has the CCD advisory from the factory for free repair. Send it in for CCD advisory before it is too late! When all functions are working but has distorted image in camera mode is due to CCD chip. Good Luck -James. for further assitance email, go to www.camerarepairjapan.com
Mar 24, 2009 | Canon Elura 50 Mini DV Digital Camcorder
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
Marantz CDR420 CD Recorder Logo
64 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
