Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
I know this is a weird q ? but does a motorola have a battery to take out i'm installing a airport extrteme and its asking me to take the battery out or turn it off ??
    Problem Solver:
  • 17 Answers
No, just pull the power cord out.
Posted on May 30, 2010
I have an older Garmin which I've used without problems for several years and just bought a new 1370T which I tested on a 700-mile trip. 99.9 % of the time it worked flawlessly and predictably but the 0.1%...
mcdevito75 here, If your garmin is 99% ok, you may have to deal with the 1 % errors. Remember no GPS is stsated as flwless, and we need 4--5 statlite hook ups for GPS. I'm in Florida and Use my Venturer GPS at times it takes an hour to go someplace and only 20 minutes to return, go figure I guess.
Jul 02, 2010 | Garmin nuvi 1370T Car GPS Receiver
Just got a new router (motorola) and airport will
Check your connections:
DSL-modem to telephone-jack (or cable-modem to cable-jack).
Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
Ethernet cable from LAN port on router to WAN port on your Airport.
Cut the power to the Airport, and then plug it back in, so that it restarts.
Apr 17, 2010 | Apple AirPort Extreme Router
Motorola t5720 walkie talkie not transmitting or receiving
To answer your questions: the airport xray should not have harmed them, and there is no reset button.
If you are using the radios with the rechargeable battery pack, it most likely needs replaced. They have a life expectancy of 12-18 months. Here is a link to the Motorola store: http://www.store.motorola.com/mot/en/US/adirect/motorola;jsessionid=B7997F21F6A409F029D6DEC2CB194ADB.mot2?cmd=catDisplayStyle&entryPoint=adirect&catKey=601560&messageType=catDisplayStyle Clean your battery contacts both in the radio and on the battery with a pencil eraser.
There is also a chance the radios are not programmed correctly. Be certain the frequency, interference code eliminator and the Qt filter (if any) are set identical to one another. You indicate you have a manual, I will insert a link here for those who do not, who might read this: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Lastly, you may simply have one radio which has failed. It is not likely both would fail at the same time, short of battery issues. The three items listed above are suspect: batteries, programming or one has failed.
Best regards.
Oct 20, 2009 | Motorola Talkabout T5720 (7 Channels)...
Internet connection drops within 5 min after (re)booting Airport
Speak with your internet provider, it sounds to me that the apple people didnt know what the problem was without getting down and dirtyy with it so they replaced it hoping for an easy fix. Seems to me that either the internet signal is being interrupted between the isp and your home .. or the motorola modem is having problems. I have never been a fan of motorola modems to begin with. Also the rentals u get from cable companies are used.. and typically subpar bottom of the line equipment that fail often. IF you think you will be using cable internet for years to come, purchase a linksys modem, as it is you are paying $3-5 a month for the rental of the modem. But I digress, speak with your isp and see if they cant troubleshoot the problem.. if 2 airports are having the same problem the chances of it being the airport... slim to none. good luck with all of this post again if nothing changes.
Aug 26, 2009 | Apple AirPort Extreme Router
Arris Modem won't work with Airport Express
Not sure how helpful this will be, as I'm running a different piece of gear, plus it requires both troubleshooting + ISP assistance.  I had a similar problem with my AirPort Extreme: AirPort Extreme saw the Arris, iBook saw the AirPort Extreme, but no internet connectivity.
  1. In my case, I needed to set the AirPort to DHCP in the AirPort Utility application.
  2. Power down the AirPort Extreme
  3. Power down the Arris. You achieve this by unplugging the Arris *and* removing the back-up battery.
  4. Wait a few moments.
  5. Insert the battery into the Arris.
  6. Plug in the Arris power supply.
  7. Wait for the Arris to go through the restart protocol; when all the lights on the front panel are solid green, the start-up is complete.
  8. Power up the AirPort Extreme; wait for the front panel light to go solid green.
As I was doing this, I had my ISP on the phone that confirmed complete connectivity of the signal path and ensured that I was online.  While the Arris was powered down, my ISP also sent a "message" to the Arris; I don't know if this was a software update or what.  I completed the AirPort set-uo through the Utility application, the AirPort restarted, and I was online.
Hope this helps.
Mar 17, 2009 | Arris Touchstone 450a (CM450) Modem
Razor making double beeps or weird sounds while on battery seems to be going down quick
remember to turn your bluetooth off and set the backlight lower. the double sound is probably telling u low battery
Aug 16, 2008 | Motorola Mobility RAZR V3
Macbook Pro airport extreme
You should only use Windows xp for running a program that is not yet available from Apple. There shouldn't be much reason to link to the net while in Windows. Also while in Windows you are wide open to any viruses that exist. Try getting your work done without getting on the net, then go back to your Apple format. There you are 99% free of viruses. … Still need to link onto the net let me know I will ask at our Apple Computer Club on Monday
Dale
May 10, 2008 | Apple MacBook Pro Laptop Computer with...
Airport Extreme 802.11g
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
Apr 14, 2008 | Apple iMac G5 Desktop
Installing new battery
sir their is no need to unwrap that cover coz its a paer sheiled of ur battery if u wil remove it ur battery may collapse with metal
Oct 11, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Weird
Take out the battery, wait 20 seconds, then put the battery back into the phone. That will help you reset it. If you havent dropped it at all or that much, you might want to ask your provider about any possible recalls on situations like that. My treo had a recall. I didnt know until it was out of the warranty...call them before its too late for you!
Sep 17, 2007 | Motorola Mobility RAZR V3
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
60 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
