Question about Peg Perego John Deere Gator HPX Ride on Toy
Cahnge the back wheels
Change the back wheels
    An expert whose answer gotĀ voted for 100 times.
    Habit-Forming:
  • 156 Answers
You take the black center cap off and take the nut of the axle. You just need to make sure you know the style of rear wheel for gator models.
I get my Peg perego wheels at http://www.mypegperegoparts.com/
They also helped me with my repair as well.
hope this helps
Posted on Jun 08, 2010
Tail lights only one side works
Hi it may be a blown fuse, Im unsure where the fuse box is on a Ford focus (under the hood, underneath the steering wheel or down the side of dashboard at passenger side)
It will tell you which fuse is for what on the under side of the fuse cover or in your instruction manul.
Simply change the fuse with the exact same amp.
Once fuse is cahnged, check lights.
If taillight still isnt working it may be the light connector itself behind the light cluster.
Hope this helps
Mar 08, 2012 | 2001 Ford Focus
I have an 2.4L Audi A6 multitronic 2007 model which is binding rear wheels. I have had the master cylynder changed, discs cahnged, both rear calipers changed, rear break pads changed and the boost also...
if you have had all them parts changed and its binding one moment then not working correct. the possible problem can be the abs unit, when you apply the brakes the abs controls the pressure. if the vale in the abs unit is faulty you can get this problem and worse. you may not even get a code as the coil is still fine is just its stuck. i would have this part checked or replaced.
Jun 14, 2017 | Audi A6 Cars & Trucks
Whitch side of the heater core does the hose from thermostat go or does it matter?
It should not matter. If you hook it up backwards from the original configuration it may back flush the core and cause your coolant to be dirtier than before. If it does - cahnge your coolant. You have a 50 / 50 cahance of getting it right. (good odds) If it causes a problem - change it back :)
Nov 28, 2010 | 1999 Mercury Sable
How do you change the batteries in BUzz?
The compartment for the battery is located at the back of buzz. You have to unscrew using aa small crew driver to open the lid before cahnging the batterie.
Nov 13, 2010 | Thinkway Toy Story Buzz Lightyear Space...
How do i cahnge the background on my acer aspire one netbook.its not letting me change it
go to control panel...click on display..(if you downloaded wallpaper or have photos on pc) browse and find the theme yiu want..save to background...or if you are on the internet right click and save as background one of these should work
May 20, 2010 | Acer Aspire One PC Notebook
When to change bearing in 04 camry
If you are refering to wheel bearings, then one of the best symptoms is to listen. Are you hearing a heavy drone that seems to cahnge in pitch, or go away when cornering? You can also lift the vehicle up and shake the wheels. Grab the top and bottom of the tire when lifted and move in and out. If there is movement, the bearing should be replaced.
Mar 26, 2010 | 2004 Toyota Camry
Fuel pump problem
what do you want to know. i cahnge a lot of these, its common, if needs changing the tank has to come off. a meduim job, get everything from, drop a little then unplug, you get trouble with rusty jubilee clips and putting the filler kneck back on, get a mate to help, hope its low on fuel.
Jun 16, 2009 | 1997 Land Rover Discovery
Car runs regardless of remote, it responds to change of direction, but you cannot control the car stopping or going. When you turn the car on, the wheels just start going.
cahng the baterries of the remote control for a brand new if the problem still you cant fix it contac tyco to see if they can check your car
Jun 15, 2009 | Mattel 1:32 Scale Tyco Radio Controlled...
Ipod languages
press menu button on the click wheel until you get to the main screen (screen doesn't change anymore) select the 3rd option down, then the 13th option down. then english
Dec 16, 2007 | Apple iPod nano
Can't cahnge time on Rado Esenza
if it's like that, and it had sensors then get a magnet and change the time. just put the magnet on the sign where it says + or - and it will change :)
your welcome
Oct 12, 2007 | Rado Esenza Midi R26497102 Wrist Watch
Peg Perego John Deere Gator HPX Ride on Toy Logo
171 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
