Question about Haier Dehumidifiers
The red TANK FULL light flashes, but the tank has already been emptied. I removed the filter, too.
  • littlebarefe May 30, 2010
    YES!!!! Never realized I could reset by pressing the ON button and HOLDING it down. Thank you! worth the 12 bucks, in my opinion!
  • 4,924 Answers
Than you should see why the sensor still indicates that is full...just ope and chack again to be placed in proper way ...than if all ok...try to reset it ...if it has a reset button just press it and hold it down ..if not just shut it down ..remove from the plug ...and after a while plug t again ..and when power it ...keep the button pressed fro a few seconds..most devices are reset this way ..
if it has a display and a menu ..look in the menu for reset options ...
Posted on May 30, 2010
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Red exclamation sign blinking
Dehumidifier? Sounds like a warning of some sort. A humidifier does a simple job, removing moisture from the air. If yours is not set up to drain, it could have a full holding tank. Empty it out and give it a rinse and it should be good. Drop a couple drops of chlorine bleach in it to keep down the mold growth.
If it isn't a full tank, it could be an air filter that needs cleaning or replacing. Often these things are programmed in and needs to be cleared. Clean and or replace any and all air filters and look for a reset button.
Good luck.
Mar 15, 2014 | Dehumidifiers
I have a slow blinking red light - not working
Normally, the slow blinking red light, indicates that the water collection tank/bucket is full and needs to be emptied. If the bucket is NOT full, it indicates that the tank/bucket was not installed or reinstalled properly, because it did not make secure contact with the bucket removal safety switch. Removing the bucket and reinstalling it properly will normally resolve the problem. Make sure the bucket fits squarely into it's holder from top to bottom.
In case you have misplaced your Owner's Manual, I have included a link to it, that you can download and print for future reference. http://www.appliancefactoryparts.com/content/pdfs/117029-1.pdf
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
The red indicator light just flashes when i turn the unit on. Whats wrong?
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Good luck.
Aug 12, 2010 | Kenmore 54351 Dehumidifier
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
The bucket is empty, but when I plug it the full
I thnk your tank is askew. Adjust the osition of the tank until the light goes off ...
Oct 10, 2009 | Maytag M7DH65B2A Dehumidifier
A red light saying full is on. what does that mean? this is a Westpointe de-humidifiier
it means you tank is full of water and needs to be emptied
you can slide it out, dump the water ( i use it for my garden)
then replace the tank
the light should go out
Oct 09, 2009 | Midea MDC-45AE Dehumidifier
Newair ADS-300 Dehumidifier
Nov 12, 2008 | NewAir ADS-300 Dehumidifier
Dehumidifiers Logo
69 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
